1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Thermodynamics Help
  1. Jan 16, 2008 #1
    How much heat is required to raise the temperature of 0.250kg of water from 20.0oC to 30.0oC?
    If this amount of heat is added to an equal mass of mercury that is initially at 20.0oC, what is its final temperature?
    2. Relevant equations
    Q=c*M*(t2-t1)
    3. The attempt at a solution
    for the first part i got
    q=1*0.250*(30.0-20.0)
    q=10.4725
    this is wrong the correct answer was 1.05*10^4
    how did they get that answer?
    The second part i have so far
    1.05*10^4=c*0.250*(t2-20)
    it didnt say what the spefice heat of mercury was so i looked it up and it was 0.140
    1.05*10^4=0.140*0.250*(t2-20)
    1.05*10^4/(.035)+20
    please help with this
  3. Jan 16, 2008 #2
    hage567
    For the first part why are you using 1 for c? Look up the specific heat of water. Regardless, I don't see how you got 10.4725 from your equation for q. Is there a typo in there somewhere?
  4. Jan 17, 2008 #3
    Andrew Mason
    You have to be clear on your units. You appear to be working in calories and kg. If so, you have to use a specific heat for water in calories/kg deg not calories/g deg.
    AM
  5. Jan 17, 2008 #4
    i just said find the answer in joules
  6. Jan 17, 2008 #5
    Andrew Mason
    If you are using a specific heat of 1 for water you are working in calories/g. Kelvin. If you want the answer in joules you have to multiply the answer by 4.186 (ie. 4.186 J in one cal.). The specific heat for water in Joules/Kg K is 4186.
    AM
Similar Discussions: Thermodynamics Help
  1. Thermodynamic .help (Replies: 1)
  2. Thermodynamics help (Replies: 2)
  3. Thermodynamics Help (Replies: 2)
  4. Thermodynamics help (Replies: 22)
Loading...
