Paymemoney
- 175
Hi
The following questions i am having trouble solving and need some help:
A 50.0g copper calorimeter contains 250g of water at 20.0 degrees C. How much steam must be condensed into water if the final temperature of the system is to reach 50.0 degrees C.
Unsure about the rule to use.
[tex]m_cu * m_cu + m_w * c_w = m_cu * c_cu ( T_f - T_i ) + m_w * c_w ( T_f - T_i )[/tex]
[tex]0.5 * 387 (30) + m_w (4186)(30)[/tex]
[tex]m_w = 4.9kg[/tex]
i know this is incorrect, what should be the right way to approach this question?
A cylinder contains a mixture of helium and argon gas in equilibrium at 150 degrees C. What is the rms speed of each type of molecule?
[tex]\frac{1}{3}NmV_(rms)[/tex]
My only problem i am having is finding the molecular mass. i found some hints online about this but i don't understand.
One of the answer they got was:
Helium = 4.003 * 10^-3kg/mol.
The part i don't understand is where they got 10^-3?
P.S
P.S
