Thermodynamics - RMS speed
WolfeSieben
So this is the final section of a problem I had posted earlier, and I'm kinda stumped again.
The rms speed of the molecules in 1.2 g of hydrogen gas is 1800 m/s.
300 J of work are done to compress the gas while, in the same process, 1500 J of heat energy are transferred from the gas to the environment. Afterward, what is the rms speed of the molecules?
E = N(1/2)mc^2
m = Mass of H molecule = 1.67 x 10^-27 kg
N = Total # of Molecules = 7.19 x 10^23 Molecules
c = RMS speed
E(total) = E1 (initial energy) + E2 (300J of work) + E3 (1500 J lost to environment)
initial Energy = N x (1/2)mC2
Which equates to 1.9 KJ earlier in the assignment.
E = (1900J) + (300J - the work done on the gas) - (1500J subtracted because it is lost to the environment)
= 700 J
Now plug this back in to solve for C^2
700J = N x (1/2)mc^2
700J = (7.19 x 10^23 Molecules)(1/2)(1.67 x 10^-27 kg)(C^2)
(c^2) = 1,166,083.6
c = 1,825 m/s
It is telling me I am wrong, so can someone shed some light on my mistake?
Thank you.
Answers and Replies
WolfeSieben
anyone?
collinsmark
1,939
(c^2) = 1,166,083.6
c = 1,825 m/s
I haven't gone through all the numbers. But for starters you might want to check the square root function on your calculator. :wink:
collinsmark
1,939
Couple of other things.
I'm not sure where you got the mass of an H2 molecule. But as I remember, there are two hydrogen atoms in a single hydrogen molecule. (It seems to me that you might have assumed one H atom per molecule.)
Beyond that, you might want to make sure you use a sufficient number of significant digits in your calculations.
WolfeSieben
Haha, oops.
Well, I tried this equation with both 1900J (total translational kinetic energy) and 3200J (thermal energy) for my E1. Using 3200 J ends up in 1,825 m/s and 1900 J ends with 1080 m/s. (both came back as incorrect)
Sorry for the confusion!!
WolfeSieben
Alright, So the calculation itself appears to you to be fine, just make sure my #'s are correct?
WolfeSieben
So I plugged in the new value:
Hydrogen atom (diatomic) 3.34 x 10^-27 kg (used 1.007g/mol / avagraddo's)
and my overall answer came out as 1,288 m/s and the assignment is still saying it is wrong.
I am obviously missing something, but I don't see what. Any help/hints would be appreciated!
Thanks
collinsmark
1,939
Don't you mean 3.34 x 10-27 kg per diatomic molecule?
Anyway, you might want to combine your formulas before plugging any numbers into them. It ends up that a lot of things might cancel out, making the overall calculations easier. It turns out that you might not even need Avogadro's number, molar masses, or any of that.
I ended up with a different answer.
WonSul
I just registered purely for this question here.
I'm also working on a similar problem but with different numbers.
Your work actually helped me since at first I ignored the initial thermal energy. So my calculation ended up being just the Ethermal from the work and heat given(ie the final). Which was wrong.
I managed to figure it out and I think I know what the problem is. Keep using the mass already given to you. 1.2g = 0.0012kg
And don't forget that Hydrogen is a diatomic gas with 3 translational 2 rotational degrees of freedom. I'm pretty sure I also saw you post the first two parts of this question. You had to use 5/3 in the first two parts. Same thing here.
E = (5/3) (1/2)mc^2
Hope that helps.
collinsmark
1,939
Oh, yeah. The rotational part too. I forgot about that. :redface:
[Edit: However, I'm not sure if the OP is supposed to consider that or not. I think it depends on the model being used.]
WolfeSieben
Perfect,
I returned to this problem and got it correct. Thank you for all of your help.
@WonSol
Just out of curiosity, do you go to UofC?
It would be quite the coincidence if two institutions had the same question, during the same week haha.
Suggested for: Thermodynamics - RMS speed
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
