1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Thermodynamics - Specific Entropy
  1. Nov 3, 2014 #1
    The mass flow rate through a steam turbine operating under steady conditions is 100 kg/s. Steam enters the turbine at 12 MPa and 400oC. A mixture of vapour and liquid water exits the turbine at 10 kPa. At the exit state 93% of the mass of the water is in vapour form. The turbine loses heat to the surroundings at the rate
    of 3 MW. Kinetic and potential energy effects can be ignored.
    a) Draw a schematic of the system and clearly indicate the system boundary
    using a dashed line. Indicate and label the mass flow inlets and outlets. Using
    arrows, illustrate the energy transfers between the system and surroundings
    by heat transfer and by work.
    b) Write a 1st law energy balance for the system that agrees with your schematic. Cancel all unnecessary terms, providing justification for why these terms can be cancelled.
    c) Draw the process on a T-s diagram, clearly indicating the state points and the isobars corresponding to the state points.
    d) Calculate the power generated by the turbine in MW.
    e) Calculate the change in specific entropy from inlet to exit in kJ/KgK.
    2. Relevant equations
    Question 2
    s1=sf + x[ sg - sf ]
    Also since there is one inlet and one exit,
    m=m1=m2
    I am pretty sure this equation will be useful as well,
    0= Q - W + m[ (h1 - h2) + ((v12 - v22)/2) + g(z1 + z2) ]
    but since kinetic and potential energy is negligible I think I can cancel out ((v12 - v22)/2) + g(z1 + z2)]
    That would leave me with,
    0= Q - W + m[ (h1 - h2) ]
    3. The attempt at a solution
    For the second question I'm not really sure what to do, I think that what I would have to do is find sg from using 12 MPa, 400oC and looking at the steam table for water.
    I'm not sure what I could do next because I would have 2 unknowns for the equation,
  3. Nov 3, 2014 #2
    SteamKing
    Staff Emeritus
    PF Rules generally ask that posters provide only one problem per thread. This policy is for the benefit of the users and the members since you are not mixing up answering different questions within a single thread.
  4. Nov 3, 2014 #3
    SteamKing
    Staff Emeritus
    Maybe not water. At the inlet, you generally use superheated steam for turbines.
    You are given the exit pressure (10 kPa) and the vapor quality of the mixture (93%). What you have to do is supply the saturated properties of the liquid and vapor phases from the steam tables at this exit pressure to determine the specific entropy of the mixture (and the enthalpy).
  5. Nov 3, 2014 #4
    Ok sorry about that! I changed this so it is now only one of the questions. So I should use the pressure table for propane to find sg and sf? Then I would use those values to find the specific entropy once it exits?
    Using,
    s =sf + x[ sg - sf ]
  6. Nov 3, 2014 #5
    Hey so I used 12 MPa and 400 C to get s1 on the superheated table for water, which was 6.0747 kJ/kgK. Then I used the pressure table for water and the values of entropy at 0.10 bar to get s2. I used the equation s=sf + x[ sg - sf ] and found that s2=7.625 kJ/kgK.
    How is that so far?
    edit: Just remembered to get the enthalpy's. For h1 I used the superheated table and got 3051.3 kJ/kg. Next I used my pressure table at 0.10 bar and found my hf and hg, from here I used,
    h2 = xhg + (1-x)hf
    and found h2 = 2417.1991 kJ/kg
  7. Nov 3, 2014 #6
    Hey I got it right! Thanks for the tip =)
  8. Nov 3, 2014 #7
    SteamKing
    Staff Emeritus
    The thermo properties look OK. Now you can finish the steam turbine problem.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Thermodynamics - Specific Entropy
Loading...
