• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Thevenin Equivalent
1. Homework Statement
Find the Thev Eq circuit for a DC power supply that has a 30-volt terminal voltage when delivering 400mA and a 27-volt terminal voltage when delivering 600mA.
2. Homework Equations
KVL: Vs=IsR1+IsR2
Vth=Isc*Rth
3. The Attempt at a Solution
Assuming that each 3volt step is a 200mA change, than Voc would be 36v. I determined the load resistance by checking both current EQs [6vload/.4A] and [9vload/.6A] and determined the solution of both to be 15ohms. I did a KVL utilizing the 30v and 400mA figures and determined that Rth is 75ohms. I then did a KVL with the other figures and received a 30ohm answer. Where have I strayed???
MATLABdude
The Thevenin voltage and Thevenin resistance are fixed for a particular black box and don't change when you hook up different loads to it. The load resistance most certainly changes, but you've basically assumed that they're constant (how else would the first circuit only draw 400 mA while the second draws 600 mA?) while the Thevenin Resistance is changing.
As you can see by now MATLABdude, Edward Lawry Norton is my arch nemesis. But I thank you for the help!
Related Threads for: Thevenin Equivalent
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
