Thin Chalkboard-Like Material?
  • Thread starter erok81
  • Tags
    Material
In summary, the conversation discusses the use of chalkboard contact paper and paint as a potential solution for erasing issues with whiteboards. The conversation also mentions alternative options such as spray paint and roll-on blackboard paint. The link to purchase the contact paper is also provided.
erok81
464
Has anyone ever seen this stuff? In class the other day one of my professors moved the sliding chalkboards around to reveal the behind-most chalkboard. As he was writing/erasing you could see the board ripple suggesting it was made from a much thinner than normal chalkboard.
I am getting sick of my whiteboard not erasing and like chalk better, so I was thinking of sticking this stuff over my current whiteboard.
Where does one locate such a product?
Something thin painted with blackboard paint?
Ah...I bet it's that contact paper stuff. Anyone used it?
I tried roll on blackboard paint over particle board and it didn't erase very well. That's why I ended up with the whiteboard.
I might get that contact paper and stick it over my whiteboard. I also thought about spraying it with that spray paint chalkboard stuff, but with how my roll on project turned out, I don't know if I'd want to try it again.
I have not personally come across a thin chalkboard-like material, but based on your description, it sounds like it could be a type of flexible or lightweight chalkboard material. These types of materials are often used in educational settings where portability and space-saving are important factors. However, I would caution against simply sticking this material over your current whiteboard without further research or consulting with your professor or school administration. Different types of boards require different types of markers and erasers, and it's important to ensure that the materials you are using are compatible to avoid damage or difficulty in erasing. Additionally, it's important to consider the durability and longevity of the material, as it may not hold up as well over time compared to a traditional chalkboard. I recommend doing some more research and possibly reaching out to manufacturers or suppliers of educational materials for more information on where to locate this product.
1. What is a thin chalkboard-like material?
A thin chalkboard-like material is a type of writing surface that is made of a thin layer of material, such as plastic or laminate, that is coated with a chalk-like substance. This allows for writing and drawing with chalk or chalk markers, similar to a traditional chalkboard.
2. What are the applications of thin chalkboard-like material?
Thin chalkboard-like material can be used in a variety of applications, such as in schools, offices, and homes for writing and drawing. It can also be used in crafts and DIY projects, as well as in restaurants and cafes for menu boards or signage.
3. How durable is thin chalkboard-like material?
The durability of thin chalkboard-like material depends on the specific type and quality of the material. Generally, it is more durable than traditional chalkboards as it is less likely to crack or break. However, it can still be susceptible to scratches and damage from harsh chemicals or excessive pressure.
4. Can thin chalkboard-like material be used with regular chalk?
Yes, thin chalkboard-like material can be used with regular chalk. However, it may be more difficult to erase compared to using chalk markers. It is important to use soft chalk and avoid pressing too hard to prevent scratching the surface.
5. How do you clean and maintain thin chalkboard-like material?
To clean thin chalkboard-like material, simply wipe it down with a damp cloth or sponge. For tougher stains, a small amount of mild soap or a non-abrasive cleaner can be used. It is important to avoid using harsh chemicals or abrasive materials, as they can damage the surface. Regular maintenance includes avoiding pressing too hard with writing utensils and periodically re-coating the surface with a chalk-like substance to ensure a smooth writing surface.
  • Materials and Chemical Engineering
  • STEM Academic Advising
