The Engineer
- 2
Will the following thin steel plate plasticly deform due to its own weight, what is the maximum deflection of the plate? Plate dimensions 0.25 cm thickness, 3.0 m length, 3.0 m width. The plate is supported on two ends, by a wall (welded).
σ = (pb^2)/[(2t^2)((0.623{b/a)^6)+1)]
y = (0.0284pb^4)/[(Et^3)((1.056[b/a]^5)+1)]
density = 8050 kg/m^3
area = (3m)(3m) = 9m^2
volume = (3m)(3m)(0.0025m) = 0.0225m^3
weight = (8050kg/m^3)(0.0225m^3)(9.81m/s^2) = 1776.83N
p = 1776.83N/9m^2 = 197Pa
σmax = ((197)(3^2))/{(2[0.0025^2])((0.623([3/3])^6)+1))} = 87.3937MPa
Therefore, no plastic deformation.
ymax = (0.0284(197)(3^4))/[((200x10^9)(0.0025^3))((1.056[3/3]^5)+1)] = 0.07053m
Therefore, the deflection is 0.07053m.
Well, that's my attempt at this problem. Not 100% sure if it's right though. :(
