Things I can't get my head around
  • Thread starter Monique
  • Tags
    Head
In summary, the conversation discusses how farmers remove the pit from olives or cherries and process mangoes so that the stone is removed, but the fruit is still in neat pieces. There is also a discussion of how to process corn on the cob.
Monique
Staff Emeritus
67
I used to have a summer job in agriculture, peeling flower bulbs and also planting tiny little plant shoots, but there are a few things I don't understand..
1) how do they remove the pit out of olives or cherries and keep the fruit intact, whenever I try to do that they are left mangled in many pieces.. I don't see how they get them out.
2) how do they process mangoes so that the stone is removed, but the fruit is in neat pieces. Whenever I try to eat a mango it becomes really messy, it is impossible to eat that fruit.
3) how do they remove corn from the cob, those things are impossible to get off!
1. There's this cool look looking machine that takes a needle and 'punches' through it to push out the seed while holding the fruit intact. Either that or genetic modification.
2. I've never seen 'processed' mangoes before, but when I eat them I take them out the same way as an avocado, but in 4 peices instead of 2, not too difficult after some practice.
3. Scrape it. As long as it's raw, if you try that after cooking it you just squish it.
1.http://shop.bakerscatalogue.com/items/Cherry___Olive_Pitter.html
2. I have no idea
3. Back in the day they used a threshing machine. I imagine it is something more complicated today but probably not as cool. http://en.wikipedia.org/wiki/Threshing_machine
In teerms of the mango, this is how the big guys do it:
Cut the mango into three pieces. Estimate where the stone is and cut down along two sides of it, trying to get as much fruit as possible. That will leave you with two sections with a flat side and a rounded side. Take a paring knife and, looking at the flat side, cut the fruit in a grid pattern, going all the way down until you get to the skin. Do not cut through the skin. You'll do vertical cuts and horizontal cuts to make a bunch of squares but it is still attached to the skin. Now, looking at the flat side still, hold it so that your thumbs are on the flat side and your fingers curl under to the round side. Now simply turn the fruit inside out (i.e. push up with your fingers while holding your thumbs stationary). The nice square pieces will pop out and you just run the knife along the skin to separate them.
It's a lot easier than it sounds here.
Hey...loookie here...I could have saved some typing:
http://phrogz.net/MangoCubes/
I have a stone pitter from the 1920's, its like a miniplunger. You put the stem side down in it and push with your thumb..and presto!
I freeze my own fresh corn. I just take a sharp parring knife and cut the raw kernels off as close to the cob as i can.
I'm not sure that I've ever eaten a mango. If I have, it was already prepared and served cut up, because I know I've never tried to cut the thing.
The olive pitter thing has been covered.
With corn on the cob, it's easiest to cut off the kernels when they are raw, but I have gotten them off of a cooked corn cob the same way too. Some mush when it's already cooked, but not too bad (when little kids are around who are still too young to eat the corn directly off the cob, this ends up being done, or back when my sister had braces on her teeth, she had to do that to eat corn on the cob too).
The trick to issues number 2 and 3 is a good sharp knife. Nothing is more handy in the kitchen, and (in my experience) harder to find in most people's kitchens. You'll have a lot more success with the mango, corn or whatever if you invest in some http://www.cutlery.com/t11t20.shtml (even just one) and keep it sharp. Struggling along with stamped blades and buying new ones when the current ones are too dull just wastes time, food and money in the long run, plus a sharp knife is actually safer than a dull one. BTW, the best part about processing your own mangos is chewing the remainder of the fruit off of the stone, very messy, tasty and fun :biggrin: (except for the fibers - floss anyone!).
mmmmmmm...mangoes...
personally I think its best not to think too much when eating mangoes, especially about how to cut them, I just enjoy them and the mess they make
Yes, I usually just get a knife and cut off bite-size pieces until I can't get through the fibres anymore, then I just start chewing the rest off of the stone like DocToxyn :smile: I should try the cutting in three parts method..
Looking at the cherry and olive pitter that Townsend mentioned it all makes sense now :approve:
One more thing: where do fruitflies come from?
"Fruit flies lay their eggs near the surface of fermenting foods or other moist, organic materials. Upon emerging, the tiny larvae continue to feed near the surface of the fermenting mass. This surface-feeding characteristic of the larvae is significant in that damaged or over-ripened portions of fruits and vegetables can be cut away without having to discard the remainder for fear of retaining any developing larvae. The reproductive potential of fruit flies is enormous; given the opportunity, they will lay about 500 eggs. The entire lifecycle from egg to adult can be completed in about a week."
Source: http://www.uky.edu/Agriculture/Entomology/entfacts/struct/ef621.htm
So you can just cut away the part rotting and eat the rest of the fruit? :rofl:
So are the eggs already there or do you need a fruitfly to lay the egg once it is rotting?
I'm convinced that the eggs must get laid while the fruit is still fresh, because there never seems to be a fruit fly in sight until they suddenly start swarming as they hatch from some fruit you didn't get to in time. Though, fruit flies also thrive in biohazard waste bins. :yuck: They seem to like the same media that bacteria like. A couple years ago, we had this sudden fruit fly infestation in our lab, and were convinced it was someone studying genetics letting flies escape or something, until we discovered they were in the biohazard barrel (we didn't fill it very quickly and hadn't used it in a while, so didn't notice until someone went to dump something else in there). We had to explain to the disposal people why we had the lid wrapped in plastic and duct-taped shut and wouldn't let them open it in the lab to check that everything inside was in a bag. :rolleyes: We now empty it on a more regular schedule, whether we've filled it or not.
Leave the fruit flies long enough in a vat of biohazard waste and soon they'll mutate into super bugs capable of flying into your ear and taking over your brain.
Moonbear, has anyone been acting strangely in the lab lately? Perhaps someone has become obsessed with eating fruit?
Here is some nice information about fruit flies:
http://www.discovery.com/area/skinnyon/skinnyon970718/skinny1.html
"They come when they smell your peaches rolling across the ripeness line."
If time flies like an arrow, why do fruit flies like a banana?
Yes, I was convinced of that too. Where is that fruitfly that is laying all the eggs? From gerben's link it says that "it's more likely that your Drosophila melanogaster came from the great outdoors than from the grocery store"..
Kind of disturbing also that the "white larvae will spend five or six days gobbling the yeast and alcohol-rich products of fermentation, then crawl out of the sludge, hatch into red-eyed monsters and start the cycle again" :eek: 5 or 6 days?
The odd thing is that I've NEVER seen fruit fly larvae in rotten fruit, just the flies, so maybe they do find their way in from outside somehow. I've grown fruit flies on purpose (hasn't every biology major had to do that for a genetics lab at some time?), so I know the larvae are big enough to see, and their eggs are pretty big too, so I just don't know where the beasts come from!
Some scientist once and for all proved that the adult fruit flies must show up and lay their eggs.
He put two hunks of bait in two bottles and put a fine screen over one of them. After a few days, he ensured he saw no flies, and then covered them both. Sure enough, within a few days, the one without the screen was rife with fruit flies.
It proved conclusively that the flies came from outside to lay their eggs. If they could not first find the bait, then no flies would be laid or be hatched.
Interestingly, the purpose of the experiment was to once and for all, disprove the hypothesis of spontaneous generation of fruit flies. Up to that point, it was generally beleived that (since no one ever seemed to see fruit flies laying the eggs) fruit flies arose from the bait itself, not from adults laying eggs.
The bait, was that meat or fruit? The experiment I remember was with house flies, not fruit flies.
What does "Things I can't get my head around" mean?
"Things I can't get my head around" is a phrase often used to describe something that is difficult to understand or comprehend. It can refer to complex concepts, confusing ideas, or even personal experiences that are hard to make sense of.
Why do some people struggle to understand certain things?
There are many reasons why someone may have difficulty understanding certain things. It could be due to a lack of prior knowledge, differences in learning styles, or even cognitive barriers that make it harder to process information.
How can I improve my ability to understand difficult concepts?
Improving your understanding of complex concepts often takes time and effort. Some strategies that may help include breaking down the information into smaller, more manageable chunks, seeking clarification from others, and finding real-life examples to help make connections.
Are there certain types of concepts that are more challenging to understand?
Yes, some types of concepts may be more difficult for individuals to understand than others. This can vary based on personal experiences, educational background, and other factors. However, with the right approach and resources, most people can eventually grasp even the most complex ideas.
Why is it important for scientists to understand difficult concepts?
As a scientist, it is crucial to have a strong understanding of complex concepts in your field of study. This allows you to accurately analyze and interpret data, make informed decisions, and contribute to the advancement of knowledge in your field. Additionally, being able to explain difficult concepts to others is a valuable skill in science communication and teaching.
  • General Discussion
