This Limit problem seems too simple...
  • Thread starter Wi_N
  • #51
vela
Staff Emeritus
Education Advisor
14,743
1,347
The Calc 1 approach to this problem is probably to multiply and divide by the conjugate:
\begin{align*}
\left(x^3 +x^2 +\frac{x}{2}\right)e^{\frac{1}{x}} - \sqrt{x^6+1}
&= \left[\left(x^3 +x^2 +\frac{x}{2}\right)e^{\frac{1}{x}} - \sqrt{x^6+1}\right]\frac{\left(x^3 +x^2 +\frac{x}{2}\right)e^{\frac{1}{x}} + \sqrt{x^6+1}}{\left(x^3 +x^2 +\frac{x}{2}\right)e^{\frac{1}{x}} + \sqrt{x^6+1}} \\
&= \frac{\left(x^3 +x^2 +\frac{x}{2}\right)^2e^{\frac{2}{x}} - (x^6+1)}{\left(x^3 +x^2 +\frac{x}{2}\right)e^{\frac{1}{x}} + \sqrt{x^6+1}} \\
\end{align*} It's fairly straightforward to analyze the problem from here with the usual Calc 1 methods.
  • #52
623
190
Generally, you can't because cancellation may occur. If you can see that cancellation won't occur, then you can do the replacement. In this thread's problem, the leading order term is going to cancel, so it's not obvious you can simply discard the lower-order terms in the polynomial.
So how can generally foresee that it is not OK to substitute a function with its asymptotic equivalent?
  • #53
13,458
10,518
It is ok. You simply have to consider all factors, quotients, sums and differences to determine what asymptotic really is!
Likes archaic
Related Threads on This Limit problem seems too simple...
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
