Homework Help: Thomae Function
  1. Mar 1, 2012 #1
    Show the Thomae's function f : [0,1] → ℝ which is defined by [itex]f(x) = \begin{cases} \frac{1}{n}, & \text{if $x = \frac{m}{n}$, where $m, n \in \mathbb{N}$ and are relatively prime} \\ 0, & \text{otherwise} \end{cases}[/itex] is Riemann integrable.
    2. Relevant equations
    Thm: If fn : [a,b] → ℝ is Riemann integrable for each n, and fn → f uniformly on [a,b], then f is Riemann integrable.
    Trying to do this without invoking any sort of measure theory/Lebesgue integration.
    3. The attempt at a solution
    I've been stumped on this one for awhile now. Basically I've been trying to construct a sequence of Riemann integrable functions from [0,1] to ℝ that are continuous (and therefore Riemann integrable) that converge uniformly to Thomae's function. Unfortunately, I haven't been able to construct such a sequence of functions. The function that I'm trying to "tweak" right now is:
    gn : [0,1] → ℝ defined by [itex]g_n = x \cos^{2n}(p! \pi x)[/itex].
    I need to show that gn is continuous for each n (easy). I need to show that gn converges uniformly to the function g : [0,1] → ℝ given by
    [tex] g(x) = \begin{cases} x, & \text{if $x=k/p!$, where $0 \leq k \leq p!$} \\ 0, & \text{otherwise} \end{cases} [/tex]
    Here lies a bit of a mental barrier for me. I know that I haven't showed that g(x) = f(x), but I'm having trouble showing that gn → g uniformly since the value of g depends pointwise on x. I argue that if x is of the form k/p!, where 0 ≤ k ≤ p!, then gn(x) → g(x) uniformly (i can show this). Then I argue that this implies that if y is "otherwise," then gn(y) → g(y) uniformly as well since g(y) ≤ g(x), where x is of the form mentioned above.
    Anyways, I'm having a hard time believing my own argument. Does this work? If it doesn,t is it even possible to construct a sequence of continuous functions converging uniformly to Thomae's function?
  3. Mar 1, 2012 #2
    Bacle2
    Do you know of any results relating the set of points of continuity to Riemann
    integrability?
  4. Mar 1, 2012 #3
    No I don't. I need to show this using uniform convergence (if that is possible).
  5. Mar 1, 2012 #4
    Bacle2
    A suggestion:
    Try defining a sequence that mimicks/approaches the Thomae function.
    Start with an enumeration of the rationals, and assume they are given
    in reduced/lowest form. Then define f_n(x). You can
    start by defining f_1(x)=1/m for x=a_1, and ? otherwise . Does that help?
    I'm sorry, I must go for a few hours; if I'm not back tonight, I will be back tomorrow.
  6. Mar 1, 2012 #5
    Sorry I'm a bit confused when you say an enumeration of the rationals. Arn't the only rationals we're concerned about between 0 and 1? Can you elaborate a bit more on how you're defining f_n and what is a_1?
  7. Mar 1, 2012 #6
    Bacle2
    Yes, sorry, I meant the rationals in [0,1]. Since the rationals are countable,
    we can arrange them as a sequence {rn} , which assigns to n the
    n-th rational, and we assume we have these rationals in lowest terms, i.e., if
    rn=an/bn, then :
    gcd(an,bn)=1
    ( this reduction is always possible, e.g., by the
    fund. thm of arithmetic ). Now, I'm trying to suggest how to construct the sequence : we
    want a sequence {f_n} of
    functions that converges to the Thomae function uniformly. We can then define the first
    term f1 of the sequence like this:
    f1(r1)=f(a1/b1):=1/b1, and
    f1(x)=0 for x in [0,1]\{r_1}; f_2(a_1)=1/b_1 ; f_2(a_2)=1/b_2 ; f:[0,1]\{r_1\/r_2}=?
    Can you see how to continue defining f2(r_n), and then fn?
    Does that help?
  8. Mar 2, 2012 #7
    Yes. That makes perfect sense. Thank you. Currently I'm working on showing fn → f uniformly.
Loading...
