Three Charges in a Triangle
  • Thread starter odesa
Three electrons form an equilateral triangle 1.00 nm on each side. A proton is at the center of the triangle. What is the potential energy of this group of charges?
U = K q1 q2 / r
K = 9*10^9
q = 1.6*10^-19
First I made the triangle and tried to get the U of the three negative charges. I did (9*10^9)(1.6*10^-19)^2/(1*10^-9) and multiplied this by 3 because there are 3 different PE combinations with the negative charges and got 6.912*10^-19. Then i found it for the positive and negative charges and there are also 3 combinations for this. I calculated the distance from the negative to the positive charge to be .66 nm and then i used the same formula multiplied by 3 to get 1.05*10^-8.
Now I tried adding the PE's together but the first number is negligible compared to the second. I'm not sure if I made a mistake in calculating the radius, or if there is another point I'm missing on how to figure out the total PE. Thanks in advance.
Answers and Replies
Related Threads on Three Charges in a Triangle
  • Last Post
9K
