• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Three piece explosion question
Question: If a container explodes and breaks into three fragments that fly off 120 degrees apart from each other, with mass ratios 1 : 4: 2. If the first piece flies off with a speed of 6m/s what is the speed of the other two fragments. (All fragments are in the plane.)
I do not even know how to set up this problem. I know that the momentum before the explosion has to equal the momentum after the explosion. But there is no starting velocity of the container before the explosion.
I just need some help setting the problem up.
Thank you
Stephen
Doc Al
Mentor
44,681
1,000
Assume that the speed of the container before the explosion was zero.
458
If there is no starting momentum before the explosion, then there will be no NET final momentum.
Maybe Stephen needs to be reminded that to utter the phrase "conservation of momentum" means that you have two equations: one equation consisting of all x-components, and one equation consisting of all y-components.
ok
so
0= m*6cos(theata) + 4m*Vxcos(theata) + 2m*Vxcos(theata)
0= m*6sin(theata) + 4m*Vysin(theata) + 2m*Vysin(theata)
But what would theata equal?
458
Draw a picture, break the momentums into x and y vectors as mikelepore said, and use trigonometry.
right
so the first mass would be at 120 degrees thus x=-6cos60 and y=6sin60 since 180 - 120 = 60
the second mass would be at 240 degrees thus x=-Vcos60 and y=-Vsin60 since 240-180= 60
the third mass would be at 360 degrees thus x=Vcos0 and y=Vsin0 since 360 is at zero.
Is this right?
thus the two equations are:
7mVfx= -3m-2Vxm + 2Vxm
7mVfy= 3sqrt(3)* m - 2*sqrt(3)*Vy*m + 0
Right?
The velocities could be:
0.9m/s and 3m/s
or
1m/s and 3m/s
or
1.5m/s and 09m/s
or
1.5m/s and 3m/s
would the velocities be 1.5m/s and 3m/s?
any help would be appreciated
Doc Al
Mentor
44,681
1,000
Good, but do not use the same letter (V) to stand for two different speeds. Call the speed of the second mass V and the speed of the third mass W (or whatever).
Now write your conservation of momentum equations and solve for V and W.
Are the two equations:
0= -3m-2Vxm + 2Vxm
0= 3sqrt(3)* m - 2*sqrt(3)*Vy*m + 0
Doc Al
Mentor
44,681
1,000
0= -3m-2Vxm + 2Vxm
Almost. Looks like you used Vx to stand for the speed of both mass 2 and mass 3 in that first equation. (Probably just a typo.) Correct that and you're good to go.
ok so the equations are:
0= -3m-2Vxm + 2Wxm
so:
3m+2Vxm=2Wxm
or
3/2 +Vx=Wx
and
2sqrt(3)*m*Vy=3*sqrt(3)*m
Vy=(3*sqrt(3))/(2sqrt(3))
Now what?
Doc Al
Mentor
44,681
1,000
0= -3m-2Vxm + 2Wxm
There are only two speeds; call them V (mass 2) and W (mass 3). I'd write the equations as:
0= -3m -2Vm + 2Wm
0= 3sqrt(3)*m - 2*sqrt(3)*V*m + 0
Work from there and solve for V & W.
OK so:
3/2 +V=W
V=(3*sqrt(3))/(2sqrt(3))
Now do I replace V in 3/2 + V = W so I would get a value for V and W?????
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
