Calculating .001^100 on TI-83: Results & Accuracy
  • Thread starter CarbonBased
  • Tags
    Ti-83
In summary, the person asking the question was wondering why their TI-83 calculator was giving them an answer of zero when attempting to calculate .001 to the 100th power. Another person explained that this is due to the calculator's limitations in storing numbers with infinite digits and rounding errors with very small numbers. They also suggested looking into other calculators with better precision or simply calculating it manually. The conversation also mentioned that the TI-83, TI-85, and TI-89 give slightly different answers for this calculation.
CarbonBased
This is probably an ignorant question...but why when I attempt to calculate .001 to the 100th power on my TI-83 does it give me an answer of zero? Is the calculator assuming that the answer is so close to zero that it is negligible? If so, that's probably not the accuracy I'm looking for.
Mathematics news on Phys.org
Yup, the calculator sees it just like a 0. Calculators can't store numbers with inifinite digits, plus you get roundinig erros with very small numbers.
.001 = 10^(-3)
.001^(100) = (10^(-3))^100 = 10^(-300) = 0.000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001
My TI-84+ can't handle anything with exponents greater than 99 or less than -99, probably some sort of memory limitation. I don't think the 83 is any better. You can probably find better arbitrary precision calculators online, or the TI-89 seems to handle this calculation fine. (Although, for something like this, you would just figure it out normally like Diffy did.)
That's interesting. Even in "scientific" or "engineering" mode, the TI83 gives an answer of "0E0".
The TI85 and TI89, however, give "1.00E-300".
Ok...that makes sense. And yea I suppose it's pretty simple to work out mentally; I just wanted to diagnose my TI's issues. Thanks for the insight:)
What is the purpose of calculating .001^100 on TI-83?
The purpose of this calculation is to determine the value of a very small number raised to a large power. It may be used in various scientific and mathematical equations, such as in probability and statistics.
How do I perform this calculation on a TI-83 calculator?
To calculate .001^100 on a TI-83 calculator, press the "Y^x" button, then enter .001 as the base and 100 as the power. The result will be displayed on the screen.
What is the result of .001^100 on TI-83?
The result is 1 x 10^-200, or 0.00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001. This is a very small number, close to zero but not exactly zero.
Is the result accurate on a TI-83 calculator?
The result displayed on the calculator is accurate to the number of decimal places shown, but it may not be exact due to limitations in the calculator's display and rounding capabilities. It is recommended to use scientific notation to represent the result for greater accuracy.
Why is the result of .001^100 on TI-83 displayed in scientific notation?
The result of this calculation is a very small number, and it is more convenient and accurate to display it in scientific notation rather than a long string of zeros. Scientific notation also allows for easier comparison and manipulation of very large or small numbers.
  • Computing and Technology
9K
13K
