- #1
Euphoriet
- 105
- 0
I'm wondering how to set my ti 89 to ... " | x does not equal 3, and x does not equal 4 " for any partifular function... I tried a comma and a "|" still no go...
In order to input an equation into the Ti-89 calculator, you can use the "Y=" button on the calculator and enter your equation using the appropriate variables and symbols.
To solve for x using the Ti-89 calculator, you can use the "Solve" function. Simply enter your equation into the calculator and then press the "Solve" button. The calculator will then provide you with the solution for x.
Yes, the Ti-89 calculator has the ability to solve for x with multiple variables. You can enter your equation with multiple variables and then use the "Solve" function to solve for x.
Yes, when solving for x with the Ti-89 calculator, it is important to use the correct syntax and notation. For example, use parentheses when necessary and use the appropriate symbols for operations (such as ^ for exponents).
Yes, you can solve for x with inequalities using the "Solve" function on the Ti-89 calculator. However, it is important to note that the solution will be an interval rather than a single value.
