Tight-binding model
  • Thread starter Niles
Niles
1,868
Hi
I've been reading about the tight-binding model, and I have some questions. Lets say we have the Hamiltonian H for our lattice, and it satisfies
Hψ = Eψ,
where ψ is a vector containing the wavefunction for each atom in the lattice. When I solve the above equation e.g. numerically, I get the eigenvectors ψ. In my case the ψ's just contain numbers, but does this mean that the waverfuncion for each atom is constant?
Answers and Replies
kanato
415
No, it doesn't mean the wavefunction is a constant.
Say you have two atoms in the unit cell, and one orbital for each atom. Then your Hamiltonian is 2x2, and your wavefunction is a two component vector. The values of these components indicate the relative contribution of each atom. If [tex]\phi_i(r)[/tex] are your basis orbitals, then your wavefunction is
[tex]u_k(r) = c_1 \phi_1(r) + c_2 \phi_2(r)[/tex]
Note that this is the solution for the periodic part of the Bloch wavefunction, so there is a long range exp(ik*r) phase factor.
Niles
1,868
Ok, so the two eigenvectors I get have the above form. Does each eigenvector (and corresponding eigenvalue) corresponding to a single particle state? I.e., eigenvector #1 is for the single particle state at atom #1 and eigenvector #2 is for the single particle state at atom #2?
I really appreciate this. Thanks.
kanato
415
Yes they refer to single particle states. But the second part is wrong.
If you have two eigenvectors, they will be of form (a, b) and (-b, a), as required by orthogonality. The first state (a,b) will be a single particle state that has a contribution a from atom 1 and a contribution b from atom 2. You will not get "eigenvector #1 is for the single particle state at atom #1 and eigenvector #2 is for the single particle state at atom #2?" unless b = 0, which will only happen if your Hamiltonian is diagonal. Both eigenvectors will have contributions on both atoms for realistic tight binding models.
Niles
1,868
Thank you. That clarified it for me.
Suggested for: Tight-binding model
  • Last Post
  • Last Post
  • Last Post
  • Last Post
