1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Tightening the charged sphere
  1. Aug 16, 2014 #1
    A metal sphere, of radius R and cut in two along a plane whose minimum distance from sphere's centre is h, is uniformly charged by a total electric charge Q. What force is necessary to hold the two parts of the sphere together?
    2. Relevant equations
    Elestrostatic equations
    3. The attempt at a solution
    After the cut, the charges would get redistributed along the section, right? I figured a spherical cap repelling the other piece as they would get the same charge signal, so the neccessary force to hold them both is the repelling force F,
    F = EQ
    E is the electric field
    How can I calculate this E through the spherical cap??
  3. Aug 16, 2014 #2
    rude man
    I wouldn't think in terms of an actual cut. The two quasi-hemispherical sections are joined together so all the charge is on the joined sphere's round surface, but there is a repulsive force trying to separate the two sections.
    Beyond that I have no hints to offer.
  4. Aug 16, 2014 #3
    Good call, as the force gets the quasi-hemisferical sections together, the charges will remain in the sphere's surface. I will retry it later.
  5. Aug 17, 2014 #4
    rude man
    Good luck with this, I suspect it's a tough problem, probably belongs in the advanced physics forum.
    WAG: there's a line thru the center of the sphere and perpendicular to the cut. For each sphere section there's a point on this line where the net force in the direction of the line is zero (taking one section at a time). If you were to put the respective surface charges Q1 and Q2 at those two points, could you argue F = k Q1 Q2/d^2 where d is the distance separating those two points?
Have something to add?
Draft saved Draft deleted
Similar Threads - Tightening charged sphere Date
Find the charge of Capacitor 2 in the circuit Today at 8:55 AM
Charged pendulum in magnetic field Saturday at 12:36 PM
Net electric force on a charge Thursday at 11:53 PM
How large is the force that tightens the wire May 12, 2014
How tightening a string affects frequency? Nov 24, 2011
