Homework Help: Time averages and Phasors
  1. Jul 20, 2009 #1
    Current and Phasors
    Statement:
    A simple circuit is given, such that the AC power source "V" is in parallel with a resistor "G" (why would it be denoted by G instead of R?), and also parallel with a capacitor "C".
    Relevant equations:
    Converting the circuit to phasors, the current from the source is given by:
    [tex]I = GV + C\frac{dV}{dt} = GV + j\omega CV[/tex] (#1)
    I know [tex]I = \frac{V}{R}, C\frac{dV}{dt}[/tex] are equations of ohm's law for a resistor and capacitor respectively. I also know by Kirchhoff's law the sum of the
    "branches" is equal to the main source.
    My Question:
    I am not sure what the symbol "G" denotes (in my notes I wrote that G = 1/R), nor sure how to get the second equality in equation (#1). I wrote in my notes that GV is a
    constant so there is no derivative of it. But how do we take the phasor form (and derivative?) of [tex]GV + C\frac{dV}{dt}[/tex]
    thank you,
    JL
  3. Jul 20, 2009 #2
    CEL
    Re: Current and Phasors
    G is the notation for conductance, the inverse of resistance. Ohm's law can be written
    V = RI
    or
    I = GV.
    GV is not a constant, since V is variable. To derive GV, follow the rule of derivation of a function (V) multiplied by a constant (G).
  4. Jul 20, 2009 #3
    I almost understand, but I still don't know how the phasor form from my question.
  5. Jul 20, 2009 #4
    CEL
    The current GV is in phase with the voltage. The curent [tex]j \omega CV[/tex] is 90 degrees out of phase with the voltage.
  6. Jul 20, 2009 #5
    I'm guessing thats the same as writing [tex]\frac{Vcos(\omega t + \theta - 90\circ)}{\frac{1}{\omega C}} = \frac{Vsin(\omega t + \theta)}{\frac{1}{\omega C}}?[/tex]
    Thanks
  7. Jul 20, 2009 #6
    But why is there no imaginary "j" term in the notation above to match [tex]j\omega CV?[/tex]. I've derived the equation above by assuming the power source is given by the equation [tex]Vcos(\omega t)[/tex]. Since the current though a capacitor is defined by [tex]C\frac{dV}{dt}[/tex], then we can write [tex]C\frac{d(Vcos(\omega t))}{dt} = \frac{Vsin(\omega t + \theta)}{\frac{1}{\omega C}}}.[/tex]
  8. Jul 20, 2009 #7
    CEL
    Because [tex]j\omega[/tex] corresponds to [tex]\frac{d}{dt}[/tex]
  9. Jul 20, 2009 #8
    So anything involving derivatives (rates), in particular capacitors only have imaginary components? And anything that doesn't involve derivatives, such as resistors- like lightbulbs or whatever- only have real components? If this is true, do you mind explaining why that is so?
    Thanks so much,
    JL
  10. Jul 20, 2009 #9
    CEL
    Not only elements involving derivatives. Elements involving integrals too. In the case of electrical elements, these involve capacitors and inductors.
    If you apply the Laplace transform to an integro-differential equation, the derivatives become s and the integrals, 1/s, where [tex]s = \sigma + j\omega[/tex] is the Laplace variable.
    The real term [tex] \sigma[/tex] corresponds to the transient response, while the imaginary term [tex]j\omega[/tex] corresponds to the steady state response.
    If you are interested only in the steady state, you replace s by [tex]j\omega[/tex] .
