In summary, the time delay margin refers to the amount of time that a system can withstand before it becomes unstable. A large time delay margin is generally considered good for ensuring safe stability, but it can also slow down the system's response time. This creates a trade-off between stability and responsiveness. In certain applications, such as fighter aircraft flight control, minimal phase and gain margins are often specified. Design engineers aim for a fast response time, but this may result in minimal margins. Typically, a minimal phase margin is specified and can be converted to a time margin at critical frequencies.
Abdul Wali
33
I have a question regarding the time delay margin. I know the definition of time delay margin now I want to know that for the stability of the system is it good to have large time delay margin or small time delay margin?
A large margin is good for safe stability, but it may make the system slow to respond. So there is a trade-off. In something like a fighter aircraft flight control, minimal phase and gain margins will be specified. The design engineers will try to get a fast responding plane, but that will probably get them close to the required minimal margins. Usually it is a minimal phase margin that is specified and that can be converted to a time margin at the critical frequencies.
Likes berkeman
1. What is time delay margin?
Time delay margin is a measure of how much time can pass before a system becomes unstable. It is the difference between the actual time delay of a system and the critical time delay at which the system becomes unstable.
2. Is a large time delay margin better than a small one?
In general, a larger time delay margin is considered better because it indicates that the system has a greater tolerance for time delays before becoming unstable. This allows for more flexibility and stability in the system.
3. How is time delay margin calculated?
Time delay margin is calculated by subtracting the critical time delay (the time at which the system becomes unstable) from the actual time delay of the system. The result is the time delay margin.
4. What factors can affect the time delay margin?
The time delay margin can be affected by various factors such as the type of system, the complexity of the system, the accuracy of the sensors and actuators, and external disturbances or noise. It can also be influenced by the design and tuning of the system.
5. How can time delay margin be improved?
To improve the time delay margin, the system can be designed with faster sensors and actuators, as well as more accurate feedback control algorithms. The system can also be tuned to reduce the effects of external disturbances and noise. Additionally, reducing the complexity of the system can also help improve the time delay margin.
  • Electrical Engineering
  • Quantum Physics
  • Electromagnetism
