Exploring Spacetime Metric for Clock A's Time Interval
In summary: You can use the Euler Lagrange equation for a geodesic to get rid of one equation.You can use the Euler Lagrange equation for a geodesic to get rid of one equation.
  • #36
betel said:
The second term has two be without the 1/2 because you get twice the same contribution from the t-r and r-t.
Then you can combine the two.
You also know, that it is back at r=0 at tau=4. That will be enough.If you take the correct equation for t it will be easier.
So I find [itex]r(\tau)=-\frac{1}{2} \tau^2+2 \tau[/itex]
and then the t equation becomes
[itex]
\frac{d^2t}{d \tau^2} + \frac{1}{(1+r)} \frac{dt}{d \tau} \frac{dr}{d \tau}=0
[/itex]
What do you mean by now I can combine the two? Do you mean substitute the for r into the t equation or do you mean do some further simplification? Presumably further simplification because substitution yields:
[itex]\frac{d^2t}{d \tau^2} + \frac{- \tau + 2}{ -\frac{1}{2} \tau^2 + 2 \tau + 1} \frac{dt}{d \tau}=0[/itex]
which doesn't look very promising!
  • #37
Dammit again, I only checked you had tau^2, but didn't check your factor which is wrong. You made a mistake when you integrated. Otherwise correct.
[itex]
[/itex]
Well, that's possible to solve. But it is easier if you look a the bare t equations. Try to write it as one total derivative. Then you are down to only a first order equation.
  • #38
So do we agree that the equation to solve is
[itex]
\frac{d^2r}{d \tau^2} - \frac{1}{2} g_{\alpha \beta} u^\alpha u^\beta=0
[/itex]
But then using [itex]g_{\alpha \beta}u^\alpha u^\beta = g^{\alpha \beta} u_\alpha u_\beta=-1[/itex] for timelike curves we get
[itex]\frac{d^2r}{d \tau^2} +\frac{1}{2}=0[/itex]
As far as I can see integrating this straight up gives the same as last time?
Although I notice that if I do this with an auxiliary equation I get something with sine and cosine in it - this is definitely wrong so what is the reason why we can't use an auxiliary equation here?
  • #39
[itex]
[/itex]
You are fine up to here. But upon integrating you forgot the factor. Just reverse check from your solution and you will see.
  • #40
Oh yeah...it appears I forgot the basic rules of integration momentarily!
Ok so [itex]r(\tau)=-\frac{1}{4} \tau^2 + \tau[/itex]Now, as for this t equation, I really have no idea how to rewrite this. I assume we do something fancy with the [itex]\frac{1}{1+r}[/itex] and [itex]\frac{dr}{d \tau}[/itex]?
  • #41
Correct.
Maybe it will help if you multiply the equation through by 1+r, then it is easier to see. You will get it at once if you use the alternative version of the geodesic equation we derived before.
You can also insert the solution for r in the equation for the norm of the velocity which will give the same equation for t.
  • #42
betel said:
Correct.
Aaarghh! I'm getting confused.
We had [itex]\frac{d u_\alpha}{d \tau} - \frac{1}{2} \partial_\alpha g_{\mu \nu} u^\mu u^\nu=0[/itex]
so to match up with our t equation we take [itex]\alpha=t,\mu=t,\nu=r[/itex]
but then we have a [itex]g_{rt}=0[/itex] and I get confused because this removes all r dependence from the t equation so i have clearly gone wrong somewhere!
  • #43
No, everything fine. just remember the difference between co and contravariant velocity.
  • #44
You cannot really choose mu and nu, But by choosing alpha=t and as no metric component depends on t the last some will be zero.
  • #45
So this tells us that [itex]\frac{du_t}{d \tau}=0[/itex]
But [itex]u_\alpha = g_{\alpha \beta} u^\beta = g_{\alpha \beta} \frac{d x^\beta}{d \tau}[/itex]
And so [itex]\frac{d}{d \tau} ( g_{tt} \frac{dt}{d \tau})=0[/itex]
But now what?
We know [itex]g_{tt}=-(1+r)[/itex]
So expanding gives [itex]-\frac{dr}{d \tau} \frac{dt}{d \tau} - (1+r) \frac{d^2t}{d \tau^2}=0[/itex]
But I thought we just showed that [itex]\frac{d^2t}{d \tau^2}=0[/itex]?
I appear to be going round in circles!
  • #46
Take a break. You have shown
[tex]
\frac{d}{d\tau} \left((1+r)\frac{dt}{d\tau}\right)=0
[/tex]
which is correct. No need to expand. You can directly conclude
[tex]
\frac{dt}{d\tau}=\frac{const}{1+r}
[/tex]
The constant still has to be determined but this can be done from the norm of the velocity.
Now just insert your solution for r and integrate.
  • #47
[tex]
[/tex]
[tex]
[/tex]
The norm of the velocity for a timelike curve is [itex]g_{\alpha \beta} u^\alpha u^\beta = -1[/itex]
so [itex]-(1+r) \frac{k^2}{(1+r)^2} + \frac{1}{1+r} ( - \frac{1}{2} \tau + 1 )^2 =-1[/itex]
since [itex]\frac{dr}{d \tau}=-\frac{1}{2} \tau +1[/itex]
so [itex]-k^2 + (1-\frac{1}{2} \tau)^2 = - (1+r) \Rightarrow k^2=1+r + (1-\frac{1}{2} \tau)^2[/itex]
[itex]k^2=1+ \tau -\frac{1}{4} \tau^2 + 1 - \tau + \frac{1}{4} \tau^2=2 \Rightarrow k = \sqrt{2}[/itex]
I took the positive root but presumably the negative is also valid or is there a reason for chosing one or the other?
And so [itex]t(\tau)=\frac{\sqrt{2} \tau}{1+r}[/itex]
Now I have to get the substitutions right - do I substitute [itex]t=4[/itex] or [itex]\tau=4[/itex].
Well we have derived the geodesic equations for clock B and so clock B will correspond to proper time in this case and t will be the coordinate time (i.e. that of the observer).
So [itex]t(4)=\frac{4\sqrt{2}}{1+0}=4 \sqrt{2}[/itex]
Is this correct?
  • #48
Fine up to here. Either one is good, as time should run strictly monotoneous. Usually we choose time to be increasing
You have to integrate the derivative of the time and remember that r depens on tau too.
Is this correct?
The consideration is correct, the value is not.
  • #49
You have to integrate the derivative of the time and remember that r depens on tau too.The consideration is correct, the value is not.
so
[itex]t(\tau)=\int \frac{ \sqrt{2} \tau d \tau}{ -\frac{1}{4} \tau^2 + \tau + 1} = \sqrt{2} \frac{1}{ -\frac{1}{4}} \int \frac{ \tau d \tau}{ \tau - 4 \tau - 4} = -4 \sqrt{2} \int \frac{ \tau d \tau}{ ( \tau -2 - 2 \sqrt{2})( \tau -2 + 2 \sqrt{2})}[/itex]
Now partial fractions gives me
[itex]t(\tau)=-4 \sqrt{2} ( \frac{1+ \sqrt{2}}{ 2 \sqrt{2}}) \int \frac{d \tau}{ \tau -2 -2 \sqrt{2}} - 4 \sqrt{2} ( \frac{\sqrt{2}-1}{2 \sqrt{2}}) \int \frac{d \tau}{ \tau -2 + 2 \sqrt{2}}[/itex]
[itex]=( \sqrt{2}-1) \ln{( \tau -2 -2 \sqrt{2})} + (1- \sqrt{2}) \ln{( 2 +2 \sqrt{2})}[/itex]
And so
[itex]t(4)=( \sqrt{2}-1) \ln{(2-2 \sqrt{2})} + (1- \sqrt{2}) \ln{(2+ 2 \sqrt{2})}[/itex]
How's that?
  • #50
latentcorpse said:
so
One tau to much here.
But partial fractions is a good way to go later.
  • #51
Baah! I'm an idiot!
Ok so I get
[itex]t(\tau)=-4 \sqrt{2} \int \frac{1}{4 \sqrt{2}} \frac{d \tau}{\tau -2 - 2 \sqrt{2}} - 4 \sqrt{2} \int (- \frac{1}{4 \sqrt{2}}) \frac{d \tau}{\tau -2 + 2 \sqrt{2}}[/itex]
[itex]=- \int \frac{d \tau}{\tau -2 -2 \sqrt{2}} + \int \frac{d \tau}{\tau -2 + 2 \sqrt{2}}[/itex]
[itex]= \ln{( \tau -2 + 2 \sqrt{2})} - \ln{( \tau -2 -2 \sqrt{2})}[/itex]
and so
[itex]t(4)=\ln{( 2+ 2 \sqrt{2})} - \ln{( 2 - 2 \sqrt{2})} = \ln{ \frac{ 2 + \sqrt{2}}{2 - \sqrt{2}}}[/itex]
  • #52
latentcorpse said:
Baah! I'm an idiot!
Ok so I get
How did you get the 1/4Sqrt(2) prefactor. Without that i agree
and so
I think you missed the lower limit.
  • #53
Sorry, i was a bit too quick. I get only a prefactor of 1/2Sqrt(2) and taking the lower limit gives me 4 times your result.
  • #54
We covered that point already.
  • #55
pfff, not my day. I missed the 2, so your prefactor is all fine. But you still have to include the lower limit.
  • #56
[itex]\frac{dt}{d \tau} = \frac{\sqrt{2}}{-\frac{1}{4} \tau^2 + \tau + 1} = - 4 \sqrt{2} \frac{1}{ \tau^2 - 4 \tau - 4} = - 4 \sqrt{2} \frac{1}{( \tau -2 - 2 \sqrt{2})( \tau -2 + 2\sqrt{2})}[/itex]
Now [itex]\frac{1}{( \tau -2 - 2 \sqrt{2})( \tau -2 + 2\sqrt{2})}=\frac{A}{\tau -2 - 2 \sqrt{2}} + \frac{B}{\tau -2 + 2 \sqrt{2}}[/itex]
So to get B
[itex]\frac{1}{\tau - 2 - 2 \sqrt{2}} = \frac{A ( \tau - 2 + 2 \sqrt{2})}{ \tau -2 - 2 \sqrt{2}} + B[/itex]
set [itex]\tau = 2 - 2 \sqrt{2} \Rightarrow B= -\frac{1}{4 \sqrt{2}}[/itex]
and similarly we find [itex]A=\frac{1}{4 \sqrt{2}}[/itex]
this means then that
[itex]t (\tau) = -4 \sqrt{2} \frac{1}{4 \sqrt{2}} \int_0^\tau \frac{d \tau}{\tau -2 - 2 \sqrt{2}} - 4 \sqrt{2} (-\frac{1}{4 \sqrt{2}}) \int_0^\tau \frac{d \tau}{\tau -2 + 2 \sqrt{2}}[/itex]
[itex]=-\int_0^tau \frac{d \tau}{\tau -2 - 2 \sqrt{2}} + \int_0^\tau \frac{d \tau}{\tau -2 + 2 \sqrt{2}}[/itex]
[itex]=-\ln{(\tau -2 + 2 \sqrt{2})} + \ln{(2 \sqrt{2} - 2)} + \ln{( \tau -2 - 2 \sqrt{2})} - \ln{(-2-2 \sqrt{2})}[/itex]
So [itex]t(4)=\ln{2+ 2 \sqrt{2}} - \ln{2-2 \sqrt{2}} - \ln{ 2 \sqrt{2} - 2} + \ln{-2 - 2 \sqrt{2}}[/itex]
[itex]=\ln{ \frac{(2 + \sqrt{2})(-2 - 2 \sqrt{2})}{(2-2 \sqrt{2})( 2 \sqrt{2} - 2 )}[/itex]
[itex]=\ln{ \frac{-12 - 8 \sqrt{2}}{-12 + 8 \sqrt{2}}[/itex]
How's that?
Thanks!
  • #57
So to get B
How's that?
Thanks!
I think that is what I got. You should swap the denominator, otherwise you take log of something negative.
  • #58
well I can simplify it to
[itex]\ln{\frac{-3-2 \sqrt{2}}{-3+2 \sqrt{2}}}[/itex]
Clearly that argument is negative which causes problems but what do you mean swap the denominator?
Also, why was it convenient (or necessary?) to rewrite the geodesic in that covariant way? Would it not have worked if we had just used the standard geodesic equation and if not, why not?
How did you know you had to rewrite it that way?
Thanks very much for your help on this question!
  • #59
When getting log as the result of an integral you always have to take absolute values. So if you ignore it at the start, you have manually correct later.
[/QUOTE]
Thanks very much for your help on this question![/QUOTE]
Not neccessary, but this form of the geodesic equation is of more practical use in some cases. Otherwise you have to first calculate all the Christoffel symbols and then sum. Here if your metric does not depend on a couple of coordinates, because of the partial derivative the geodesic equation for such coordinates will be very easy.
And I knew it was a practical way to rewrite it because I gave the question to my students rececently.
