Time-dependent wavefunction
  • Thread starter physgirl
If given, for instance, psi(phi, 0)=[1/sqrt(2pi)](cos^2(phi/2) + isin(phi)), which is the wavefunction at t=0, how do you go about finding the wavefunction at time t, psi(phi,t)??
Would it simply be psi(phi, t)=psi(phi,0)e^(-iEt/hbar)??
The given wavefunction is for a particle on a ring.... and for that, E_n=(hbar^2)(m^2)/(2I) where I=mr^2. Is that the value of "E" I plug into the above equation??
Is there any other constant that I have to multiply the psi(phi,t) equation by as a result of adding on the e^(-iEt/hbar) term??
Any help would be great, I'm not entirely sure if I get this :-/
Answers and Replies
Avodyne
87
In general, you have to write the initial wave function as a sum of energy eigenfunctions with suitable coefficients. Then, as time evolves, each term gets multiplied by e^(-iE_n t/hbar), where E_n is the eigenenergy of that eigenfunction.
I'm not sure how to express psi (phi, 0) as a sum of energy eigenfunctions in this case...
Avodyne
87
What are the energy eigenfunctions?
If it's a free particle on a ring, they should be e^(i n phi), n=...,-1,0,+1,..., up to normalization. (The m^2 in your E_n should be n^2, no?)
Your psi(phi,0) is some trig functions; can you express these in terms of complex exponentials?
yes and yes. (1/sqrt(2pi))e^(i n phi) is the eigenfunction. and I really meant n^2 when I said m^2 previously...
I just expressed my psi(phi, 0) in exponential terms. The psi I gave in the original post left out some constants, but when I do take into account those:
psi(phi,0)=sqrt(1/4pi) (e^(i phi) + 1)
but how does this get into a summation form..? :-/
Avodyne
87
It already is in a summation form. You have
psi(phi,0) = (1/sqrt(2))( psi_1(phi) + psi_0(phi) ),
where psi_n(phi) is the eigenfunction.
Related Threads on Time-dependent wavefunction
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
