Does Earth's Elliptical Orbit Affect Time Dilation Due to Gravity?
In summary, Earth does experience varying degrees of time dilation from gravity due to its elliptical orbit around the sun. This is caused by a combination of the varying speed along the orbit and the gravitational pull of the sun. The exact amount of time dilation depends on the frame of reference, but if we consider a distant clock on a line perpendicular to Earth's orbit, time on Earth would be slower in January compared to June. A ring of clocks placed along Earth's orbit would also display differences in time due to this gravitational time dilation.
nitsuj
1,389
98
Relative some arbitrary point in Earth’s orbit around the Sun, does Earth experience varying degrees of time dilation specifically from gravity?
With Earth's orbit around the sun being elliptical I wondered if Earth experiences varying degrees of time dilation caused by the suns gravity (or moon for those cycles).
For example in January we are closest to the sun and farthest in June.
Is time slower in January relative to June.
Generally, the answer to your question is yes, with some caveats and clarifications. First, note that speed varies along the orbit. However, this adds to the gravitational time dilation (faster when closer), so competing effects don't need to be balanced - instead they add to each other. More important, the question really has no meaning without a definition of 'slow relative to what'? Locally, you measure no changes at all.
However, if ones asks what is the total redshift of signals you send, when received by an observer at infinity (assuming asymptotic flatness), you have a well specified question. With this clarification, you could say time on Earth runs slower in January compared to June as perceived by observers at infinity (or, for practical purposes, distant radial observers).
I'd like to add one more caveat about this. If you ask about clock time on Earth compared to a single distant clock, the situation is more complex if the distant clock is in the plane of the ecliptic - orbital motion towards and away from that clock would become significant.
So, to get a reasonably simple statement you could say: Compared to a distant clock on a line through the sun, perpendicular to the ecliptic, time on Earth would be slower in January than in June.
So if I get what your saying, I forgot to mention a frame of reference?
What about a ring of clocks, initiated simultaneously, all along Earth's elliptical orbit around the sun, do they all display the same time after a year? (just gravity)
Yes, that would just measure gravitational time dilation differences for 'hovering observers' (note these are a special class of non-inertial observers; the orbiting Earth is inertial - excluding its rotation). You would indeed see the clocks at perihelion fall behind the other clocks, with the one at aphelion being most in the lead.
What is time dilation in Earth orbit?
Time dilation in Earth orbit refers to the phenomenon in which time moves at a slower rate for objects in orbit around the Earth compared to objects on the surface. This is due to the effects of gravity and the speed at which objects are moving in orbit.
How does time dilation affect astronauts in space?
The time dilation experienced by astronauts in space is very small, but it can still have a noticeable effect. Astronauts will age slightly slower than their counterparts on Earth, and they may experience slight differences in the timing of events compared to people on the ground.
What causes time dilation in Earth orbit?
Time dilation in Earth orbit is caused by two factors: gravity and velocity. The closer an object is to a massive body, such as the Earth, the greater the gravitational pull and the slower time will pass for that object. Additionally, objects in orbit are also moving at high speeds, which also contributes to time dilation.
How is time dilation measured in Earth orbit?
Time dilation in Earth orbit is measured using atomic clocks. These clocks are extremely precise and are used to measure the effects of time dilation on objects in orbit. By comparing the time on a clock in orbit to a clock on the surface, scientists can determine the amount of time dilation that is occurring.
Can time dilation in Earth orbit be observed from Earth?
Yes, time dilation in Earth orbit can be observed from Earth. The effects are very small, but they can be measured using precise instruments. For example, GPS satellites use atomic clocks that are corrected for the effects of time dilation in order to accurately transmit location information to devices on the ground.
