Time Dilation: Explaining Why Velocity of Light is Perpendicular
In summary, when trying to find a formula for time dilation, it is common to think of a situation where the velocity of the other frame is perpendicular to the velocity of light. This is done as it makes the derivation easier for beginning students. However, it is possible to consider a situation where the frame and light are traveling in the same direction and think of a "length expansion" in the other two dimensions. However, it is much easier to do it the traditional way.
tomz
35
Hello
When we try to find a formula for time dilation, we think of a situation where the velocity of the other frame is perpendicular to the velocity of the light
(http://en.wikipedia.org/wiki/Time_dilation)
Why is this? I know if we try any other direction there is length contraction involve. But the proof of length contraction goes after that right?
why not derive the formula for time dilation by considering a situation where the frame and the light goes in the same direction and then think there is a 'length expansion' for all object in the other 2 dimensions other than the direction of travel (relative to us)?
tomz said:
Hello
Why is this?
Because it makes the math easier for beginning students to do the derivation. It does not matter what the angle is, it's always the same.
Also see: "Michealson-Morely experiment".
Because it is much much easier to do it this way around.
Give it a go and see :D
What is time dilation?
Time dilation is a phenomenon in which time appears to slow down for an object in motion relative to an observer. This is a consequence of Einstein's theory of relativity.
How does time dilation relate to the velocity of light?
According to Einstein's theory of relativity, the speed of light is constant for all observers regardless of their relative velocities. This means that as an object's velocity approaches the speed of light, time for that object will appear to slow down for an outside observer.
Why is the velocity of light perpendicular in time dilation?
The velocity of light is perpendicular in time dilation because according to the theory of relativity, the speed of light is constant and does not depend on the relative motion of the observer. This means that the light will always travel at the same speed, regardless of the observer's velocity, and will therefore appear perpendicular to the direction of motion.
What are some examples of time dilation in everyday life?
One example of time dilation in everyday life is the Global Positioning System (GPS) on our smartphones. The satellites in the GPS system are moving at high velocities relative to the Earth's surface, causing time to dilate for them. This effect must be taken into account in order for the GPS system to function accurately.
How is time dilation measured and calculated?
Time dilation can be measured and calculated using the Lorentz factor, which takes into account an object's velocity and the speed of light. This factor is used in the equations for time dilation to calculate the difference in time experienced by an object in motion compared to an outside observer. Time dilation can also be measured experimentally using atomic clocks.
