Time Frame of Sun on Ecliptic Plane vs Equitorial
In summary, the Sun's time frame on the ecliptic plane is based on Earth's rotation and lasts approximately one day, while its time frame on the equatorial plane is based on its annual orbit around the Sun and lasts around 23 hours and 56 minutes. Both of these time frames change throughout the year due to the tilt of Earth's axis, which affects the length of daylight hours and ultimately the seasons. In astrology, the ecliptic plane is used to divide the zodiac into 12 signs and the equatorial plane is used to measure the position of planets and stars, making the Sun's time frame on both planes important in astrology and horoscopes.
Philosophaie
462
The Earth rotating on its equitorial axis spinning on its poles. The Sun has its orbit on the ecliptic 23 degrees away from the spin if the Earth. Is the time frame different at the Earth on the Ecliptic plane rather than the Equitorial?
Astronomy news on Phys.org
What?
Please rephrase your question.
Since Sidereal time is the time frame for the Elliptic and standard time is time frame for the Equitorial. How do you equate the two?
How do I find out the Ecliptic Longitude from the Sidereal Time?
1. What is the difference between the Sun's time frame on the ecliptic plane vs the equatorial plane?
The ecliptic plane is the apparent path that the Sun takes through the sky as seen from Earth, while the equatorial plane is an imaginary plane that divides the Earth into northern and southern hemispheres. The time frame of the Sun's movement on the ecliptic plane is based on Earth's rotation, while its time frame on the equatorial plane is based on its annual orbit around the Sun.
2. How long does the Sun stay on the ecliptic plane compared to the equatorial plane?
The Sun stays on the ecliptic plane for approximately one day, as it appears to rise and set in the sky due to Earth's rotation. However, it stays on the equatorial plane for a longer period of time, around 23 hours and 56 minutes, as it completes one full rotation on its axis during its annual orbit around the Sun.
3. Does the Sun's time frame on the ecliptic plane and equatorial plane change throughout the year?
Yes, the Sun's time frame on both planes changes throughout the year. This is due to the tilt of Earth's axis, which causes the Sun's position in the sky to shift and change the length of daylight hours. This results in the Sun's time frame on the ecliptic and equatorial planes to vary throughout the year.
4. How do the Sun's time frames on the ecliptic plane and equatorial plane affect the seasons?
The Sun's time frame on the ecliptic plane and equatorial plane play a crucial role in determining the seasons. When the Sun is on the equatorial plane, it is directly above the equator and this results in equal amounts of daylight and nighttime hours, creating the equinoxes. When it is on the ecliptic plane, its position is tilted towards or away from the sun, resulting in longer or shorter daylight hours and creating the solstices, which mark the start of the summer and winter seasons.
5. How does the Sun's time frame on the ecliptic plane and equatorial plane affect astrology?
In astrology, the ecliptic plane is divided into 12 equal segments, known as zodiac signs, which are used to predict personality traits and future events. The Sun's time frame on the ecliptic plane affects the duration of each zodiac sign, with each sign lasting approximately one month. The equatorial plane is used to measure the position of the planets and stars in the sky, which is a crucial aspect of astrology. Therefore, the Sun's time frame on both planes plays a significant role in astrology and horoscopes.
  • Astronomy and Astrophysics
112K
