Time library in python
  • Python
  • Thread starter dacruick
Currently I have a program in which I want to compare times. I have
dt = datetime.now()
x = dt.time()
which gives me the current time in Hours:Minutes:Seconds:MicroSeconds.
I also have variables HourStart, MinuteStart, HourEnd,MinuteEnd. Which are the hours and minutes that are the bounds of my program running.
I want to compare times. So I want to convert HourStart MinuteStart etc to time types. So if HourStart = 10 and MinuteStart = 30. I want to represent that as a time type being 10:30:00:000000
any help is appreciated
Answers and Replies
The python datetime docs is full of info and examples. Generally, the docs are the best place to start looking for info on how to do anything.
dt = datetime.now()
x = dt.time()
Unless I've got the wrong end of the stick, this appears to be very straightforward. Suppose that we have ints start_hour, start_min, end_hour, and end_min. You can construct time objects from these by calling the datetime.time constructor:
Code:
start_time = datetime.time(start_hour, start_min)
end_time  = datetime.time(end_hour, end_min)
You can then compare these to the time portion of a datetime.date object. For instance, if you define dt = datetime.now(), you can determine whether the end time is before now by
Code:
end_time < dt.time()
You've most likely got it right. I tried that already but I think I was having a lot of trouble with my libraries and how I'm calling my objects. I'll give it a shot
At the top of my program I've got the following libraries
from datetime import *
from time import *
and I did a little program just to test out your suggestion and received the following error:
TypeError: descriptor 'time' requires a 'datetime.datetime' object but received a 'int'
from time import *
This could be one of several things. Could you post your code here so I can have a look?
As of right now I don't have much of a code, but my issue is outside of the rest of my code anyways. I have a function that returns two floats, starttime and endtime.
basically what im doing is this:
dt=datetime.now()
while starttime < float(dt.strftime('%H')) + float(dt.strftime('%M')/60) < endttime:
so what I want to do is convert all of those floats into a datetime, for a more seemless comparison. thanks
I was able to use dt.time() to convert it to something like hours:minutes:seconds.microseconds, which works well for my purposes. But its quite annoying when i try to convert my floats into time format. thanks again.
Related Threads on Time library in python
28K
11K
  • Last Post
  • Last Post
  • Last Post
