Satvik Pandey
- 591
- 12
Estimate the time it takes a pencil of length L=10 cm to hit the ground if initially the pencil makes an angle of 0.001 rad with the vertical. Take the gravitational acceleration to be 10m/s2
Details and assumptions
Assume that the pencil is just a thin solid rod with uniform mass distribution along its length. Also to simplify the problem, assume that the pencil's contact point with the ground (the tip) is fixed.
I[/B]nitially the rod makes 0.001 rad with vertical.
So it makes 89.947 deg with horizontal.
Torque acting along point O is ##mgcos\theta \frac { l }{ 2 } ## [I will change the units of l at end]
So
##\frac { dL }{ dt } =mgcos\theta \frac { l }{ 2 } ##
or ##I\frac { d\omega }{ dt } =mgcos\theta \frac { l }{ 2 } ##
or ##I\frac { { d }^{ 2 }\theta }{ { dt }^{ 2 } } =mgcos\theta \frac { l }{ 2 } ##
But I don't know how to solve this second order differential equation.
So I tried this
##I\omega \frac { d\omega }{ d\theta } =mgcos\theta \frac { l }{ 2 }##
or ##I\frac { { \omega }^{ 2 } }{ 2 } =mgsin\theta \frac { l }{ 2 } +C##
At ## t=0## ## \omega=0## and let ##\theta ={ \theta }_{ i }##
So ## C=-mg lsin{\theta}_{i}##
So ##I\frac { { \omega }^{ 2 } }{ 2 } =mgsin\theta \frac { l }{ 2 }-mg lsin{\theta}_{i}##
or ##\frac { m{ l }^{ 2 } }{ 3 } \frac { { \omega }^{ 2 } }{ 2 } =mgsin\theta \frac { l }{ 2 } -mgsin{ \theta }_{ i }l##
or ##{ \omega }^{ 2 }=\frac { 3\left\{ gsin\theta -2gsin{ \theta }_{ i } \right\} }{ l } ##
or ##\frac { d\theta }{ dt } =\sqrt { \frac { 3\left\{ gsin\theta -2gsin{ \theta }_{ i } \right\} }{ l } } ##
or ##\frac { \sqrt { l } }{ \sqrt { 3\left\{ gsin\theta -2gsin{ \theta }_{ i } \right\} } } d\theta =dt##
or ##\sqrt { \frac { l }{ 3g } } \int _{ { \theta }_{ i } }^{ 0 }{ \frac { d\theta }{ \sqrt { \left\{ sin\theta -2sin{ \theta }_{ i } \right\} } } } =t##
Am I right till here?
How to solve this integral?
