Timing circuit (lm555)
  1. Nov 25, 2008 #1
    JO3
    Hello all,
    I'm trying to make a circuit with the following properties:
    1) output at +V for a time T1
    2) output at 0 for a time T2
    repeat indefinitely
    **also, whenever contact is made between two points, I would like the circuit to jump to state 2 (contact would only be made when the system is in state 1)
    It would be good if I can adjust T1 and T2 continuously, i.e. with a variable capacitor and/or potentiometer. T1 should be about 15 minutes and T2 should be about 45 minutes, but I want to understand the circuit enough to be able to make adjustments myself. Equations would be very helpful:)
    I think I might be able to use the http://www.national.com/ds/LM/LM555.pdf" [Broken]chip, but I'm not exactly sure how to set these up. Voltage should be between 5V-15V or so.
    Thanks for your help,
    Joe
  3. Nov 25, 2008 #2
    dlgoff
  4. Nov 25, 2008 #3
    JO3
    Thanks, that site looks very helpful. I'm reading through it now.
    Joe
  5. Nov 26, 2008 #4
    berkeman
    Staff: Mentor
    Those are pretty long times to be trying to use a 555 analog timer circuit. A better solution would be to use a digital oscillator (based on a 32kHz watch crystal, for example), with divider circuits and a little logic to give you the variability you want. Check out the 74HC4060 IC and its app notes, for example.
  6. Nov 26, 2008 #5
    Averagesupernova
    WOW! I thought I was pushing the envelope timing out to around 10 minutes with a 555.
  7. Nov 26, 2008 #6
    Redbelly98
    Staff Emeritus
    I got one to go to 40 minutes. It's in a coffee-cup heater, the heater shuts off after the 555 says it's time.
    The heater circuit originally timed out at 20 minutes. I opened it up, changed a 5M resistor to 10M, and now it's 40 minutes.
  8. Nov 26, 2008 #7
    dlgoff
    I've had them work for long times also. Nice big caps.
    I think that the 555 is a good way to get your feet wet in circuit building.
