higherme
- 129
any one know where I can find the colour range of the indicator Eriochrome black T?
Eriochrome Black T Color Range is a type of chemical dye that is commonly used in analytical chemistry for the detection of metal ions. It is also known as Eriochrome Black T Indicator, and it is used to determine the endpoint of titrations.
The purpose of using Eriochrome Black T Color Range is to detect the presence of metal ions in a solution. It works by forming a complex with the metal ions, which results in a color change that can be easily observed. This color change indicates the endpoint of the titration and helps determine the concentration of the metal ions in the solution.
Eriochrome Black T Color Range is typically added to the solution being titrated, and the color change is observed as the titrant is added. The color change indicates the endpoint of the titration, and the volume of titrant needed to reach the endpoint can be used to calculate the concentration of the metal ions in the solution.
Eriochrome Black T Color Range has several advantages, including a high sensitivity to metal ions, a wide color range, and a simple and rapid procedure. It also has a high selectivity for some metal ions, making it useful for specific analytical purposes.
While Eriochrome Black T Color Range is a useful indicator for metal ion titrations, it does have some limitations. It is not suitable for titrating solutions with a low pH (<3) or high alkalinity, as this can interfere with the color change. It also has a limited shelf life and should be stored in a cool, dark place.
