Titration Questions Homework: Dry/Wet Flasks, Stoppering Flasks
  • Thread starter Badgeray
  • Tags
    Titration
In summary, the experiment involved collecting a sample of saturated Ca(OH)2 solution in flask #1, filtering it into flask #2, and transferring 25.00mL samples into flasks #3, #4, and #5. Only flask #1 could be wet since it had unfiltered solution. Flask #2 was stoppered to prevent contamination and ensure accurate Ksp calculations. The overall purpose of the experiment was to determine the Ksp of calcium hydroxide using titration calculations, and the individual transfers were necessary to ensure the solutions were accurately saturated.
Badgeray
A sample of saturated Ca(OH)2 solution in water is collected in flask #1, filtered into flask #2, then 25.00mL samples were transferred into flasks #3, #4, #5. Which flasks had to be dry and which could be wet?
Also, flask #2 was stoppered. Why?
I think only flask #1 could be wet since it is the only flask that has unfiltered solution.
I think flask #2 was stoppered since it was filtered to prevent contamination, but would it affect Ksp if it wasn't stoppered?
With no purpose stated I cannot see how it matters whether any flask is dry or wet.
Stoppering the bottle is to stop it something getting to it, what could that be?
The purpose was to determine the Ksp of calcium hydroxide using titration calculations
That's the general purpose of the whole process, but you have not stated purposes of individual transfers - and that's what matters.
Well we now know it is needed to know for sure that the solutions he gets at the end are exactly saturated. Not difficult to see what needs to be dry IMO.
What is titration?
Titration is a laboratory technique used to determine the concentration of a substance in a solution by reacting it with a known concentration of another substance.
Why is it important to use dry/wet flasks in titration?
Dry/wet flasks are important in titration because they help to control the amount of moisture in the solution, which can affect the accuracy of the results. Dry/wet flasks are used for different types of titrations, depending on the specific requirements of the experiment.
What is the purpose of stoppering flasks during titration?
Stoppering flasks are used during titration to prevent the loss of volatile substances, such as acids or bases, that are being titrated. This ensures that the correct amount of the substance is reacted and the results are accurate.
What is the difference between a dry flask and a wet flask?
Dry flasks are completely free of moisture and are typically used for titrations involving acid or base solutions. Wet flasks, on the other hand, have been rinsed with distilled water and are used for titrations involving non-acidic or non-basic substances.
Can I reuse dry/wet flasks and stoppers for multiple titrations?
It is not recommended to reuse dry/wet flasks and stoppers for multiple titrations as it can lead to contamination and affect the accuracy of the results. It is best to use new, clean flasks and stoppers for each titration.
15K
9K
21K
