To Humidify, or to De-humidify?
  • Thread starter Adrian Baker
In summary, the hardware store had a special offer on De-humidifiers and Humidifiers. The De-humidifier was on the same shelf as the Humidifier. The question is whether to buy both or just one. The practical option is to pump the De-humidifier full of liquid nitrogen and hit the air with a hammer and shovel it out before it thaws. The final conclusion is that you only need a humidifier in the middle of winter.
Adrian Baker
378
I went to my local DIY store (hardware store) today and they were doing a special offer on De-humidifiers... On the same shelf, they were selling Humidifiers!
Which one should I buy?
Do I want to be Humidified or Dehumidified??
Should I buy both and let them fight it out in a sealed room??
Which would you rather be - humidified or de-humidified? Perhaps I should start a poll? :confused:
The usual needs are a humidifier in the winter to replace moisture removed by heating and dehumidifier in the summer, when humidity is more of a problem.
So that's both then!
Life is SO complicated sometimes...
the question is- do you really need either?
My house needs a dehumidifyer (2, actually, plus extractor fans) because we have a problem with damp and mildew. Lack of humidity never seems to be an issue for us.
Awww... that's sweet. They both have someone to play with.
I think that the most practical way to dehumidify your house is to pump it full of liquid nitrogen. Then hit the air with a hammer and shovel it out before it thaws.
I like this idea. Who would win in a fight in a sealed room, a humidifier, or a dehumidifier? You could take bets.
lol I have both, here in Michigan, being surrounded by water, summers can be really hot and humid. I have a whole house air conditioner, but its expensive to run. So sometimes it makes it feel much cooler by just running the de-humidifier.
:blushing: I just need to remember to empty it
I could plumb the dehumidifier into the humidifier so that I wouldn't have to fill up or empty either. That might work.
We do both for our lab. We need a constant humidity of 45% (+/-5%) all year round, so we humidify during the winter (when ambient humidity at room temp can be as low as 5%) and dehumidify in the summertime (the building AC does most of the dehumidification, but we need to go just a little further to get within our allowed range).
Normally, around 40% to 60% is considered comfortable, for human habitation (at about 20C or 70F).
Danger said:
I think that the most practical way to dehumidfy your house is to pump it full of liquid nitrogen.
Our building (physics dept) is terribly old and has a virtually dead HVAC system. This simply does not give us the required temperatures for our cleanroom when outdoor conditions fall within a specific narrow range. Every year, for a couple of weeks we need to achieve additional cooling, beyond what the building HVAC system gives us. We do this with liquid nitrogen. We gave up on promises to fix the HVAC and designed and installed a PID controlled delivery system that pours LN into a rack of stainless steel baking trays mounted inside our supply duct. We now have beautiful temperature and humidity control, 365 days a year.
Dang, it's embarrassing when one of my jokes turns out to have a practical application. :redface:
I'm guessing this is a problem only in the summer. Normally, a healthy air conditioner will provide outlet air at a dew point of no more than 50F (typically about 40 to 45F). This corresponds to a relative humidity value of 50% which is comfortably low. Adding in the moisture produced from human respiration and perspiration will make this number no more than 60%. If the humidity is, in fact, much higher than this, I suspect there may be a problem with your air conditioner.
I only need a humidifier in the middle of winter. Some people prefer a dehumidifier in summer, but humidity doesn't bother me. Of course, depending on where you live, some people need a humidifier in the bedrooms and a dehumidifier in the basement.
So, then what do you do in the spring and fall? :devil:
Open the windows! :biggrin:
I'd almost have to say, if you don't know which one you need, you don't need one. I live in a basement apartment, and the need for a dehumidifier is readily apparent, especially in the bathroom (no fan or window). Without the dehumidifier, it doesn't take long for mold to start growing on the ceiling. :grumpy:
If you're really unsure and concerned about it, buy yourself a hygrometer. I picked one up for about $2 at my local Wal-Mart.
Yep!
Is that even up to code? Here, building code requires all bathrooms have to have either a fan or window.
We no longer have the need for a humidifier in the winter because we have a fish tank. This seems to add enough humidity to keep down static shocks, dry hair, sinus problems, etc, without adding a humidifier. In the summer, we use our central air, but our basement has two dehumidifers that we run all season.
International Mechanical Code requires 20 cfm continuous or 50 cfm intermittant mechanical ventilation, or you can prove that natural ventilation can be provided by operable windows that have enough open area to ventilate the space.
LOL. Yeah, I'm aware of the building codes, although the local ones are aren't exactly the same and subject to a bit of interpretation by a building inspector. Whenever we remodel an old house, we install a bath fan unless there's a window in the bathroom. On the other hand, when you buy a house someone else has already remodeled, it's common to find one that somebody did 'under the radar.'
On most of the old houses we've got, the bathrooms were added on after the fact (the front/back porch was converted to a bathroom) and complied with the codes of the day, which as far as I can tell were pretty basic and just required a few things like S-traps for the sinks. I've even seen a few with old drum-traps, although I get rid of those in a hurry. As for mechanical codes, I'm not sure there even was such a thing before the advent of HVAC. We usually try and bring them up to code, but unless we're doing mechanical work such as heating and air in that house, the old work is grandfathered in.
In the case of my particular apartment, I would have to drill a 4" hole through a half dozen ceiling/floor joists and a cinder block wall to properly vent a bath fan. Given the amount of work invovled and the potential structural weakening involved (I really hate drilling 4" holes in floor joists unless I just have to) I decided it was easier to just put a dehumidifier in there.
Yeah, I know. I can't design them that way, but that doesn't mean they don't get built that way. :wink:
Oh, you're living in an apt in a building you own? I thought this was a place you were renting, in which case the landlord should bring it up to code before renting it out to tenants, especially if the moisture was bothersome enough to require a dehumidifier. But if you own the place and know what you're getting into, as far as building code violations go, lack of a bathroom fan isn't high up in priority on my list of things to worry much about (I too have a bathroom where the previous owners walled over the window...I don't want to still own this house if the window ever needs replacing :eek: ...and of course didn't bother to install a fan when they did that; but I also don't use that bathroom very frequently, so am not concerned enough about moisture build-up to fix it...I've decided I'm not going to live here more than another year or so, so the upstairs bathroom isn't getting remodeled either --I was going to install fans in both rooms at once when the upstairs bathroom was gutted).
My father owns it actually. I've got a couple of houses, but they're rented out right now. I do a little work for him now and again to cover his costs for the apartment.
As for bringing the units fully up to code, it's usually not something that's required for rental, at least not in this area. The inspectors are generally just looking for major issues that could cause safety problems. For example, the windows in my apartment are about 5 feet above the floor. The fire inspector required the last owner to build steps underneath the windows so that a short person or a child could get out in the event of a fire. With the age of a typical house in the neighborhood, requiring every item in every house to be brought up to code would probably double the rental rates.
In the case of my particular bathroom, the only real problem is the ceiling directly over the shower. Again, it's some 'creative' work from a previous owner. The ceiling is only 6 feet above the floor of the shower stall and rather than using something waterproof like concrete backerboard, this 'induhvidual' used regular drywall, so over the years the moisture has started to separate the paper tape from the drywall. It also tends to absorb the water rather than just letting it drip down into the shower and down the drain (thus the mold.) The dehumidifier dries out the ceiling well enough to prevent further damage from occurring. At some point though, I'll replace that ceiling with backerboard and a good vapor barrier and that should be the end of the problem.
1. What is the ideal humidity level for a room?
The ideal humidity level for a room is between 40-60%. This range provides a comfortable and healthy environment for humans and helps prevent the growth of mold and mildew.
2. How do I know if I need to humidify or de-humidify a room?
You can use a hygrometer to measure the humidity levels in a room. If the humidity is above 60%, it is too high and you may need to de-humidify. If it is below 40%, it is too low and you may need to humidify.
3. What are the benefits of humidifying a room?
Humidifying a room can help alleviate dry skin, nose, and throat, reduce static electricity, and protect wooden furniture from cracking. It can also make the room feel warmer in the winter.
4. What are the consequences of having high humidity levels in a room?
High humidity levels can lead to the growth of mold and mildew, which can cause respiratory problems and damage to furniture and walls. It can also create a breeding ground for dust mites and other allergens.
5. Can I use the same device for both humidifying and de-humidifying?
No, you will need different devices for humidifying and de-humidifying. A humidifier adds moisture to the air, while a de-humidifier removes moisture from the air. Using the wrong device can cause the opposite effect and potentially damage your room and belongings.
  • General Discussion
9K
  • Astronomy and Astrophysics
40K
