Tokamak Requirements
What are the minimum standards for tokamak fusion? For instance, What are the ideal materials? Should you use deuterium, tritium, or a mixture of the two? How much current do you run through it before it confines the hydrogen gas enough to create fusion? Please answer.
Answers and Replies
Nevermind the hydrogen types and the current problem, I found those out. Still would like to know which would be better for body construction - stainless steel or something else.
weren't they trying to contain it with a magnetic field. are u wondering what to use to pass the current through , as for the construction im sure steel or stainless steel would be good as any .
Are you sure steel will work? I don't want a http://en.wikipedia.org/wiki/Pinch_(plasma_physics)" [Broken] going on - That'll set me back a bit.
cragar: Yeah, I would like to know what kind of wire to pass it through to optimise magnetic pressure, i'm thinking of using copper.
So- with a steel torus, copper wire, and deuterium gas, plus vacuum pumps, a high voltage power transformer and controls, I could theoretically make a device capable of creating fusion, right? The idea I had for this thread is that it would help me decide the materials I would need for making one at home. The guy in the address below made a stellarator, and I'm pretty sure I can build a tokamak for myself.
http://es.geocities.com/queralv/Home1.htm" [Broken]
berkeman
Mentor
62,548
13,357
VB, what is your intention in this? Since break-even tokamaks don't exist yet, you are intending to build a model of a sub-break-even one? Like for a museum or exhibit or something?
I am not trying to "break even" - I am trying to creat a tokamak that can achieve enough fusion through magnetic compression and ohmic heating to be detected by a http://www.bubbletech.ca/radiation_detectors_files/Bubble%20Detectors.html" [Broken]. In other words, I am hardly attempting a tokamak on the scales of ITER and the like. My main objective here is to prove that DIY tokamak fusion is possible.
mheslep
728
I am not trying to "break even" - I am trying to creat a tokamak that can achieve enough fusion through magnetic compression and ohmic heating to be detected by a http://www.bubbletech.ca/radiation_detectors_files/Bubble%20Detectors.html" [Broken] for fusors.
ZapperZ
Staff Emeritus
Education Advisor
Insights Author
35,981
4,708
There was a running joke during the height of the Fleishmann-Pons "cold fusion" debacle that went something like this:
"Did you hear the bad news about Fleishmann and Pons' assistants?"
"Yeah, they're still alive!"
As with the "do-it-yourself" accelerator thread, there is a significant safety element here that may be overlooked. The creation of neutrons in any experiment is one of the most dangerous thing you can produce, not just because it can directly hit you, but also due to the fact that it can induce residual radiation that lingers for a long time, long after you've switched off the instrument.
I would seriously question anyone giving a DIY fusion device advice of any kind, especially when a person has never worked with any fusion devices previously and is ignorant of not only safety regulations surrounding such a device, but also how dangerous something like this can be.
Zz.
berkeman
Mentor
62,548
13,357
Oh man, Zapper! You owe me a new keyboard. :rofl:
mheslep
728
While recognizing there are regulations on any type of device producing ionizing radiation, these amateur D-D fusors that place in http://www.infoplease.com/ipa/A0921262.html" are hard put to produce more than ~50e3 neutrons/s, or ~6k mrem/s/sq_cm or 0.2 mrem/sec/sq_cm at 0.5 meters using 8 n/s/sq cm/mrem (ICRU - 1971) with 2.45 mev neutrons. I expect more attention need be paid to X-ray hazzards and high voltage handling in general with these devices.
I am planning to cover the high voltage wires with pvc piping and will have a little light that shows when the machine is on, so people will know to stay away from it. When not in use, it will be unplugged and the deuterium bottle will be taken off. When being handled, I will wear safety goggles, and rubber gloves to protect me. What other safety precautions do you recommend?
-mheslep: I am not trying to go for the "easy" approach to fusion. I want to be able to prove that DIY tokamak fusion is possible
Vanadium 50
Staff Emeritus
Education Advisor
2021 Award
28,219
12,891
Don't you see a conflict with these two statements?
berkeman
Mentor
62,548
13,357
I think this discussion has gone on long enough. VB, you really need to get a clue about the dangers involved. Thread locked.
Related Threads on Tokamak Requirements
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
