chhitiz
- 221
i thought of a design for a toroidal engine. is there anyway i can check if it is actually possible to practically implement this design?
chhitiz said:i thought of a design for a toroidal engine. is there anyway i can check if it is actually possible to practically implement this design?
RonL said:http://www.autoblog.com/2008/02/11/oscillating-piston-engine-that-thing-got-a-toroid-in-it/
Are you thinking about something along these lines, or perhaps free pistons, that move in a continuous free piston full circle cycle?
Yes, a toroidal engine is a real concept that has been proposed and studied by scientists and engineers. It is also known as a ring-shaped engine or doughnut-shaped engine.
A toroidal engine works by utilizing the shape of a torus, or a donut, to create a continuous combustion cycle. Fuel and air are injected into the torus through intake ports, and then ignited by spark plugs. The resulting explosion creates a rotating force that drives a rotor, which is connected to a crankshaft to produce power.
A toroidal engine has several potential benefits, including increased efficiency due to the continuous combustion cycle, reduced size and weight compared to traditional engines, and the ability to run on a variety of fuels including gasoline, diesel, and hydrogen.
Yes, there are several challenges and limitations to consider when designing a toroidal engine. These include the complexity of the engine's shape and design, potential difficulties in controlling the combustion process, and the need for specialized materials and manufacturing techniques.
While there is ongoing research and development on toroidal engines, it is not currently possible to say whether they will completely replace traditional engines in the future. However, there is potential for them to be used in certain applications where their unique design and benefits may be advantageous.
