bzhagar
- 1
First of all I want to thank you for taking your valuable time to help me out. I typically would not ask a homework question, but I have exhausted all other resources in search for an answer to my question. I will do my best to fully summarize my situation and its circumstances, seeing as this is my first post.
I have already successfully answered questions (a)-(e). The key to (f) lies in question (b): It asks if there are multiple points that can produce a result half of the value found in question (a) and in the opposite direction. That would be a value of 9. It also dictates that you find this value as it lies on the y axis. This means (to me) that the i values will all be 0 in the cross product matrices.
A particle is located at the vector position = (6.00i + 9.00j) m and a force exerted on it is given by = (4.00i + 3.00j) N.
(a) What is the torque acting on the particle about the origin?
-18k
(b) Can there be another point about which the torque caused by this force on this particle will be in the opposite direction and half as large in magnitude?
YES
(c) Can there be more than one such point?
YES
(d) Can such a point lie on the y axis?
YES
(e) Can more than one such point lie on the y axis?
NO
(f) Determine the position vector of one such point. (Give a point on the y axis.)
I used cross products to find the first solution which was -18k N m.
I assumed that I would just rearrange the same cross product equation (RxFy - RyFx) (where R = radius, F = force) while substituting a variable for Ry, considering the Rx values to be equal to 0. I could not come up with a correct solution in this manner, so I tried another way.
My logical reasoning (which was apparently flawed) was that given a particle with only a y-component, the only forces taken into consideration would be those perpendicular to that: the i forces. So I attempted the solution by stating that:
RyFx = 9 --> 4Ry = 9 --> Ry = 2.25m
This did not produce the correct solution either. Any information or guidance you could provide me with is much appreciated. Thank you all!
-18k
YES
YES
YES
NO
