Homework Help: Torque and equilibrium
  1. Nov 16, 2008 #1
    On a seesaw, Mass A is 60 kg, mass B is 30 kg, and mass C is 10kg. Mass A is 1.0 m from the piot and mass C is 3.0 m from pivot. Calculate torques of mass A and C about the pivot. Where should you place mass B in relation to the pivot for the system to be in rotational equilibrium
    The seesaw is at an angle of 30 degrees from the horizontal. Mass A is on the left side and Mass C is on the right side
    2. Relevant equations
    torque = rFsin [tex]\Theta[/tex]
    3. The attempt at a solution
    I found the torques but i dont know if they are right
    mass A (g=9.8m/s2)
    [tex]\tau[/tex]=(1)(60g)sin 30 = 294 N[tex]\cdot[/tex]m
    mass C
    [tex]\tau[/tex]=(3)(10g)sin30 = 147 N[tex]\cdot[/tex]m
    then I tried to find where to put mass B
    [tex]\tau[/tex]mass A+[tex]\tau[/tex]massB+[tex]\tau[/tex]mass C= 0
    i dont know if i should use this equaiton of soemthing else to find where to place B
  3. Nov 16, 2008 #2
    Redbelly98
    Staff Emeritus
    Where does the 30 degrees come from? We can't see the figure, if there is one, or on which side of the pivot masses A and C are located.
  4. Nov 16, 2008 #3
  5. Nov 16, 2008 #4
    Redbelly98
    Staff Emeritus
    Okay.
    There is a problem here. Yes, the angle of the seesaw to the horizontal is 30 degrees. But what is the angle θ in the equation:
    torque = r F sinθ ?
  6. Nov 16, 2008 #5
    I got the equationn from the book since for the force what is need is the component on the horizontal
  7. Nov 16, 2008 #6
    Redbelly98
    Staff Emeritus
    Check the book formula and discussion again, what exactly does it say that angle is?
  8. Nov 16, 2008 #7
    Redbelly98
    Staff Emeritus
    Hint: if the seesaw were exactly horizontal then the forces are vertical and still exert a torque, even the the horizontal force component is zero.
  9. Nov 16, 2008 #8
    so in that case i dont need the angle because even those there is an angle in the seesaw the force is not being applied at an angle
  10. Nov 16, 2008 #9
    Redbelly98
    Staff Emeritus
    Well, basicly there are two things going on:
    1. You don't really need the angle because every term in the torque equation has the same angle factor, so these can be cancelled out of the equation.
    2. You were using the wrong angle dependence when you calculated the torques, but that doesn't really matter (see 1).
    So let's get back to the problem ...
    Mass A is on the left, so we could say that it is located at -1.0m from the pivot (note the - sign)
    Mass C is to the right, so it's located at +3.0 m.
    Can you set up the torque equation you wrote before:
    τABC= 0
    using what you know about the masses and positions of A and C? You may leave out the angle sin and/or cos stuff.
  11. Nov 16, 2008 #10
    oh ok it makes sense
    so now that everything is clear
    I set up the equation
    -1(60g)+3(10g)+ τc=0
    -588+294 + τc= 0
    r F = 294
    r (30g) = 294
    r = 1
    (g = 9.8)
    this means that mass B must be place 1 m away from the pivot ( same side as mass C) to have no net torque in the system
  12. Nov 16, 2008 #11
    Redbelly98
    Staff Emeritus
    Yes. You got it :smile:
  13. Nov 16, 2008 #12
    thank you! :)
