Torque and Force due to an external magnetic field
In summary, the torque on a magnetic dipole is given by the cross product μ × B, even if B is a function of position. The force on a magnetic dipole is zero if B is a constant, but it can be non-zero if B is non-constant. This can be seen in the example of a beam of neutral silver atoms being deflected in a non-constant magnetic field, demonstrating the importance of considering both torque and force when dealing with magnetic dipoles.
wam_mi
81
Torque N = μ ∧ B
where μ is the dipole moment of the loop,
and B is an external magnetic field.
Q1 Is it true that we can only write the Torque due to an external magnetic field in this form if and only iff B is a constant? What happens, say, if B = B * x (in the z-direction) where x is a variable, is it still possible to write Torque in this form, where μ is a constant.
Q2 Why is it that Force = 0 but Torque is not = 0 when the external magnetic field is constant?
Cheers guys
1. The torque is given by the cross product [tex]\mu\times B[/tex] even if B is a function of position.
2. The force on a magnetic dipole is given by
[tex]{\vec F}=\nabla(\mu\cdot}{\vec B}[/tex],so it vanishes if B is constant.
As a simple model, think of a bar magnet. The force on the N and S ends will be equal and opposite in a constant magnetic field.
The torque on a magnetic dipole, like a compass needle, is non-zero whenever it is in a constant magnetic field B (and if the dipole is not aligned with B). There is no net translational force on the needle, however.
If B is non constant, specifically B = B * x, where B is along z, there can also be a net translational force on a magnetic dipole. A good example is the magnetic force on a beam of neutral silver atoms, which are now known to have a magnetic moment. Because the atoms did have a magnetic dipole moment, the beam was deflected (transverse force) in a magnetic field. This was the basis of the Stern Gerlach experiments in 1921-23, which later won the Nobel Prize in physics.
What is torque in relation to an external magnetic field?
Torque is the measure of the twisting or rotational force produced by an external magnetic field on an object. It is dependent on the strength of the magnetic field and the orientation of the object's magnetic moment.
How does an external magnetic field affect the force on an object?
An external magnetic field can exert a force on a magnetic object, causing it to move in a specific direction. The strength and direction of the force depend on the strength and orientation of the magnetic field, as well as the magnetic properties of the object.
What factors can influence the torque and force due to an external magnetic field?
The torque and force produced by an external magnetic field can be influenced by various factors, such as the strength of the magnetic field, the orientation of the object's magnetic moment, the distance between the object and the magnetic field, and the magnetic properties of the object.
How can torque and force due to an external magnetic field be calculated?
The torque and force on an object due to an external magnetic field can be calculated using mathematical equations that take into account the strength and direction of the magnetic field, the orientation of the object's magnetic moment, and other relevant factors.
What are some real-world applications of torque and force due to an external magnetic field?
Torque and force due to an external magnetic field have various applications in different fields, such as in electric motors, generators, MRI machines, particle accelerators, and magnetic levitation systems. They also play a crucial role in the functioning of many electronic devices, such as speakers and hard drives.
  • Electromagnetism
  • Electromagnetism
