DiamondV
- 103
I'm confused about point 2. It says V=PQsintheta. How is that formula derived?
is a fantasy humanities.DiamondV said:Consept of the moment of a force about a point is more easily understood through applications of the vector product or cross product
I absolutely agree with you. Who can explain me on how to measure the vector of the force moment that "line of action is perpendicular to plane" were the force and its radius (do not know how is named on english this line segment) act? The analogy where the moment of force derives from the cross product is bad. Softly said.Chandra Prayaga said:The "formula" V = PQ sin(theta) is not "derived". It is part of the definition of a cross product.
Torque is the measure of the force that can cause an object to rotate around an axis. It is calculated by multiplying the force applied to the object by the distance from the axis of rotation. Moment is a specific type of torque that is applied at a particular point on an object and is used to measure the tendency of the object to rotate around that point.
Torque is calculated by multiplying the force applied to an object by the distance from the axis of rotation. Moment is calculated by multiplying the force applied to an object by the perpendicular distance from the point of rotation to the line of action of the force. The formula for calculating torque is torque = force x distance and the formula for calculating moment is moment = force x distance x sin(theta).
Torque and moment are both measures of force and their relationship is that torque is a general term for the force that causes an object to rotate, while moment is a specific type of torque that is applied at a particular point on an object. Power, on the other hand, is the rate at which work is done or energy is transferred. In the equation P=Q/t, where P is power, Q is work, and t is time, torque and moment are both involved in the calculation of work.
The sin(theta) in the formula for calculating moment represents the angle between the force applied to an object and the distance from the point of rotation to the line of action of the force. This angle is important because it determines the direction and magnitude of the moment. If the angle is 90 degrees (sin(90)=1), the moment will be at its maximum. If the angle is 0 degrees (sin(0)=0), there will be no moment generated.
Torque and moment are used in many real-world applications, such as in engineering and construction to calculate the strength and stability of structures. They are also important in the design and operation of machines, such as engines and motors. In sports, torque and moment are crucial in activities like throwing a ball or swinging a golf club. In physics, they are used to understand the rotational motion of objects and to explain phenomena like angular momentum and rotation around an axis.
