Torque bicycle Question
  1. Dec 13, 2015 #1
    Consider a 18 speed bicycle, 3 gears are rotating with the pedal and 6 gears are rotating with rear wheel. Consider that the ones rotating with pedal, have radii 10 cm, 7 cm and 5 cm and the other ones have radii 3 cm, 4 cm, 5 cm, 6 cm, 7 cm and 8 cm. Calculate the torque on rear wheel gear for each different case if you apply to the pedal a force of magnitude 343 N. The force is vertical to the pedal, and it has a length of 17 cm. Explain why a bike needs that much speed, i.e. 18 speed.
    2. Relevant equations
    Equations about the torque and momentum
    3. The attempt at a solution
    I couldnt do anything.Actually τ=dL/dt
    I thought that Fxr1=F'xr2
    here r1 is the pedal radius
    here r2 is the rear wheel radius
    cause torques must be same why τ=dL/dt And L is equal to rxp which they are not chaning during the time.Theres no external force and radius is same.
    Any ideas
  3. Dec 13, 2015 #2
    SteamKing
    Staff Emeritus
    Haven't you ever studied gear ratios and how they affect torque?
    https://en.wikipedia.org/wiki/Gear_train
  4. Dec 13, 2015 #3
    Here theres rope so v=wr here w is same for both object. v/r=v'/r' and also τ=Fr so τ'=F'r' So here I guess torque ratio will be the radius ratio ?
  5. Dec 13, 2015 #4
    SteamKing
    Staff Emeritus
    Well, a chain instead of a rope.
    Yes, radius or diameter can be used to calculate the ratio.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Torque bicycle Question
  1. Bicycle Torque problem (Replies: 1)
  2. Bicycle work question (Replies: 3)
  3. Torque question (Replies: 1)
Loading...
