revo8778
- 5
This is a problem from an experiment wherein one must find the point of equilibrium for a horizontally-projected rod that hinges from it's left endpoint. I have already performed the experiment, and now have to calculate the error by comparing the torques pulling down on the rod to the torque pulling up via a string looped around a pulley to a hanging mass. This must be done in two specific scenarios.
Givens:
Mass, length of rod: .1131kg, .577m
W1 weight attached to rod, dist. from hinge: .1177kg, .38m
W2 weight attached to rod, dist. from hinge: .2502kg, .529m
W3 weight attached to string: .2502kg
String Mount's dist from hinge: .43m
The two scenarios change the angles of the rod to the horizontal, and the pulling string to the rod.
First scenario: Angle to horizontal = 0 degrees, Angle of string to rod = 55 degrees.
Second scenario: : Angle to horizontal = 47 degrees, Angle of string to rod = 90 degrees.
I = (mr^2)/3
T = Fr(sin [theta]) = I[alpha]
I have computed all of the torques that I can; they are listed below. My problem is that I don't know how to factor in the instrinsic torque of the rod itself.
Trqe of W1: .438
Trqe of W2: 1.297
Gravity is 9.8m/s^2
