Torque Equilibrium: Find Mass & Center of Gravity
In summary, at the 50 cm fulcrum the weight is 1.5 kg more then the 300 g weight and at the 43 cm fulcrum the weight is -5.1 kg more then the 300 g weight. So at equilibrium the weights will be balanced.
Kandycat
A meter stick is pivoted at its 50 cm mark but does not balance because of the nonuniformities in its material that cause its center of gravity to be displaced from its geometrical center. However, when weights of 150 g and 300 g are place at the 10 cm and 75 cm marks, respectively, balance is obtained. The weights are then interchanged and balance is again obtained by shifting the pivot point to the 43 cm mark. Find the mass o the meter stick and the location of its center of gravity.
t1 = t2
m1gr1 = m2gr2
I tried to figure out the mass of the meter stick first by using the equation below:
m1gr1 = m2gr2
So... I plugged in the numbers (g cancels out)
(300 kg)(25 cm) = (150+x)(25 cm)
I thought it was 25 cm because from 0 to 50 cm, the diameter is 50 cm and the radius must be 25 cm. I don't know... my teacher lost me. X is the mass of the meter stick.
But I got lost and confused since there is another piece of information that I think I need to use. I don't really understand torque very well.
Part of the problem is that you have THREE weights: One from each mass, and one from the meter-stick (at some unknown location down the stick, say at position L). You need to include all torques in your equation -- the weights and the upward force from the pivot... and you really have two systems (saying that you'll probably have to solve a system of equations). Draw the free body diagrams for each case.
I also predict that you'll have to use not only counter-clockwise torque equals clockwise torqu (or net torque equals 0), but also upward force equals downward force (or net force equals 0).
So this is what I figure out... somewhat:
T1 = T2 + T3
When the fulcrum is at 50 cm:
(.300 kg)(25 cm) = XL + (.150 kg)(40 cm)
When the fulcrum is at 43 cm:
(.150 kg)(32 cm) + XL = (.300 kg)(33 cm)
X= the mass of the meter stick
L= the position where the center of gravity from the fulcrum
I sort of understand, but I'm still a bit lost on how to solve for my unknowns.
Maybe take a different approach?
The given is that you have a stick that has uncertain mass distribution. But whatever its distribution it does have a weight and a Center of Mass.
Now you also have these 2 masses 150 and 300 g. And they are placed 65 cm apart. And they also have a center of mass. What you are doing then is stacking 2 objects, one with a known weight and CoM and the other not known and you are given the resulting CoM.
Since they do that twice and move the known CoM and give you another resulting CoM you should be able to solve for the 2 unknowns - the weight and CoM of the unknown meterstick.
Just to make sure I'm right... I figured this:
At the 50 cm fulcrum:
0 = (.300 kg)(25 cm) - (.150 kg)(40 cm) - x(50 cm-L)
0 = 1.5 - x(50-L)
1.5 = x(50-L)
At the 43 cm fulcrum:
0 = (.150 kg)(32 cm) + x(L - 43 cm) - (.300 kg)(33 cm)
0 = -5.1 + x(L - 43 cm)
5.1 = x(L - 43 cm)
So using substitution... I found the mass of the meter stick to be .94 kg and the position of CoG to be 48.4 cm. Did I do it right?
Also, why isn't the force of the stand that balances the meter stick not included?
What is torque equilibrium?
Torque equilibrium is a state in which the net torque acting on an object is zero. This means that the object is not rotating or is rotating at a constant rate.
How do you find the mass of an object in torque equilibrium?
To find the mass of an object in torque equilibrium, you can use the equation torque = force x distance. By measuring the distance from the fulcrum and the force applied, you can calculate the mass of the object.
Why is it important to find the center of gravity in torque equilibrium?
The center of gravity is the point at which an object's weight is evenly distributed. In torque equilibrium, finding the center of gravity is important because it helps determine the stability of the object and ensures that it is in a balanced state.
What factors can affect torque equilibrium?
Factors that can affect torque equilibrium include the distance from the fulcrum, the force applied, and the mass of the object. Any changes in these factors can alter the net torque and cause the object to rotate or not be in equilibrium.
Can torque equilibrium be achieved in any orientation?
Yes, torque equilibrium can be achieved in any orientation as long as the net torque acting on the object is zero. This means that the forces and distances from the fulcrum must be balanced in all directions in order for the object to be in equilibrium.
20K
