Torque help, please!
  • Thread starter tydychic
tydychic
24
Flywheels are large, massive wheels used to store energy. They can be spun up slowly, then the wheel's energy can be released quickly to accomplish a task that demands high power. An industrial flywheel has a 1.5 diameter and a mass of 250kg. it's max angular velocity is 1200 rpm. a)a motor spins up the flywheel with a constant torque of 50Nm. How long does it take the flywheel to reach top speed? B) how much energy is stored in the flywheel? C) the flywheel is disconnected from the motor and connected to a machine to which it will deliver energy. half the energy stored in the flywheel is delivered in 2.0s. What is the average power delivered to the machine? D) How much torque does the flywheel exert on the machine?
3. The Attempt at a Solution
I've figured out the answers to A, B, and C. A) t=176.763 seconds. B) KE(r)=555168 J. C) Power= 138792 W. D) I read that P=torque*angular velocity; however, the answer in the book says 1.30 kNM and I continue to get 1104.47. Can calculator error really explain the difference or am I going wrong somewhere?
Answers and Replies
tiny-tim
25,836
255
hi tydychic! :smile:
if you want us to check your work, you need to show us your calculations :wink:
tydychic
24
Calculations as requested:
A) T(motor)=I*alpha. I-Beta*Mass*Radius squared, Beta =1/2. Alpha=2* Torque(motor)/Mass*radius squared= .711 rad/seconds squared.
Omega final = alpha *time. omega final = 1200rpm * 1min/60sec * 2pi rad/1 rev=125.664 rad/s.
t = omega/alpha= 176.743
B) KE(r)= .5I* omega squared - (1/2)I* omega initial squared (which equals zero, so tossing that). KE(r)=(1/4)(250kg)(.75m)^2*(125.664rad/sec) = 555168 J
C) Half the power....555168/2= 277584J over two seconds...277584 J/2sec= 138792 Watts
D) 'if the equation I read is correct...138792 W/ (125.664 rad/sec) = 1104NM, but this isn't the correct answer, so I must be doing something wrong...any clues?
tiny-tim
25,836
255
(have an alpha: α and a beta: β and a pi: π and try using the X2 tag just above the Reply box :wink:)
ah, i think you're using the wrong β …
(btw, i've never seen it called β before … is that normal?)
a flywheel is essentially a wheel :biggrin:
(btw, can you see why they build them that way?)
see some pictures at http://en.wikipedia.org/wiki/Flywheel" [Broken] :wink:
tydychic
24
If I was using the wrong Beta, then my answers for A, B, and C would be incorrect. However, they aren't, so I'm assuming Beta = 1/2 is correct....? Where does that leave D?
tiny-tim
25,836
255
hmm … strange flywheel! :rolleyes:
ok , let's check …
i'm not getting that answer …
can you please show your calculations?
tydychic
24
[tex]\alpha[/tex]=2(50Nm)/(250kg*.75m[tex]^{2}[/tex])=.711rad/s[tex]^{2}[/tex]...I guess parentheses might help. I'm sorry. Does this help?
Lusos
Hi all, I am having the same exact problem... As a matter of fact, I think that we may be in the same physics class. Hehe.
Parts A,B, and C agree with OP and the back of the textbook. However, I cannot get part D to match. According to the book, the answer is 1.5kNm yet mine continues to come out as "1104.79 kw/rad(IIRC)". Is this some sort of rounding error?
tydychic
24
You wouldn't happen to know a dude with a yo-yo, would you? Because if you did, then yes, same class. Definitely the same book.
That, I chalked up to book-error. I couldn't get any other answer and the book is known to be wrong occasionally.
Lusos
HAHA yes. I've checked my answer to the point of insanity and I am willing to bet that the book once again had a typo. Anyways, good luck with the last two. See you in class on Monday.
-Oscar
gneill
Mentor
20,945
2,886
It would appear that in this case, for part D), the book is correct with its 1.30 kNm.
Suggested for: Torque help, please!
  • Last Post
  • Last Post
23K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
