NJJ289
- 18
The uniform rod in the figure is supported by two strings. The string attached to the wall is horizontal, and the string attached to the ceiling makes an angle of ϕ with respect to the vertical. The rod itself is tilted from the vertical by an angle θ. If ϕ = 29.9°, what is the value of θ?
Tcc=Tcw
I've approached the problem with three forces acting on the object. the two string tensions at the ends of the object, and a gravity force acting on its center of mass.
The center of mass is considered the location of the axis. This let's the gravity force= zero torque and reduces the problem to simply setting the tension-torques equal since the object is in equilibrium.
so I tried
T1rsin(a)=T2rsin(b)
[r is distance to center of mass from end, and a and b are angles between force vectors and position vector r. t1 and t2 are tension forces]
this simplified out to
sin(90+[tex]\theta[/tex])cos(90-[tex]\phi[/tex])=sin(90+[tex]\phi[/tex])... which does not yeild an answer.
I subbed T1=T2cos(90-[tex]\theta[/tex]) to do this since T1 and T2 have cancelling horizontal forces.
I have literally spent hours on this problem and I'm completely stumped. Any assistance is greatly appreciated!
