Torque problem
Two masses hang from a meterstick whose fulcrum is at 50.0cm. M1=.100kg acts at 20.0 cm, what value of mass m2 at position 70.0 puts the the system at equilibrium?
(.3m*(.1kg*9.8m/s2))=(.2m*(9.8m/s2*x kg))
.294 N*m=.2m(9.8*x N)
1.47 N=9.8*x N
x=.15 kg
Is this procedure correct? The distances in the first equation are from the center of mass, which is y they are different from the distances given in the problem.
Answers and Replies
PhanthomJay
509
1.47 N=9.8*x N
x=.15 kg
In this problem, the center of mass of the meter stick is located at the pivot point. While you can sum torques about any point, it is best to sum moments about a point where a force is unknown , since it avoids having to solve for the unknown force at that point. Your procedure is nevertheless correct ( you could have saved a step by not converting mass to weight, but in general, it is a good idea to do so ).
Looks right
your process looks good to me but as PhantomJay said that is one step i would reccomend as well
ok that is what i was hoping to hear, thanks alot guys. torque is confusing but once you get the center of mass stuff down its ok,,,
Related Threads on Torque problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
