Solving Torque Question: A Plank of Length L & Mass M
  • Thread starter Natbird
  • Tags
    Torque
In summary: There should really be only one unknown for that roller force (hint, again).I don't know the direction of the force roller I thought it was only in the x direction because it was frictionlessmaybe there's an upwards force also because the plank is not merely resting against it but resting on itMaybe there's a force in the y direction too, but I can't see it.Welcome to PF!
Natbird
The question:
A plank, of length L = 3.4 m and mass M = 22.0 kg, rests on the ground and on a frictionless roller at the top of a wall of height h = 1.60 m (see the figure). The center of gravity of the plank is at its center. The plank remains in equilibrium for any value of θ >= 59° but slips if θ < 59°.
a.Calculate the magnitude in Newtons of the force exerted by the roller on the plank when θ = 59°.
b.Calculate the magnitude in Newtons of the normal force exerted by ground on the plank when θ = 59°.
c.Calculate the magnitude in Newtons of the friction force between the ground and the plank when θ = 59°.
image: http://smg.photobucket.com/albums/v231/er1smesp00n/?action=view&current=physics-1.gif
so I was just solving it as if it was a normal plank against wall style question
Sum of Forces in X direction=Force of roller - frictional force=0
Sum of Forces in Y Direction=Normal(upward force from ground)-mass(gravity)=0
Sum of Torques = Force of roller(height)-mass(gravity)cos(59°)(1.7)
I know these formulas are wrong since the Normal force does not equal mass*gravity like it should according to the equations above. How do you solve this problem.
First you notice that the roller does not apply a force purely in the x direction. You tell me the next step ...
so i assum then that the roller has a force F(roller) along the y-axis in the same direction as the Normal force
Sum of Forces in y direction=Normal+Force or Roller along Y - mg=0
Sum of Forces in x direction should remain the same as before Froller=friction
Sum of Torque= Force of roller along x(height)-Normal(0)-mg(cos59°)(1.7)+Force of roller along y(1.6)/sin59°=0
but what answer do they want for the force by the roller on the plank?
sqrt(FRx^2+FRy^2)?
and I can't figure out the math I could use... aren't there too many variables now?
What direction is the force vector from the roller? Keep in mind that it is a frictionless roller (hint). It might help you to draw the diagram, showing the vectors as well as their x- and y-components.
then I thought perhaps there's an upwards force also because the plank is not merely resting against it but resting on it
is it something to do with the fact it's a roller?
is there only an upward force?
Welcome to PF!
Hi Natbird! Welcome to PF! :smile:
As belliott4488 said, draw a diagram … and draw it to show the area round the top of the wall, very large, not like the tiny .gif picture, and with a nice round roller!
Now can you see what direction the force from the roller is in? :smile:
I think what belliott and tinytim are asking you is, is there a relationship between the critical angle and the direction of the roller force? In other words, can you take two unknowns (Froller-y and Froller-x, the legs of a right triangle) and reduce them to a single unknown hypotenuse and the sine or cosine of a known angle?
Hi Natbird! :smile:
Nice diagram … I like the colours!
(But what is that curvy force? The roller is frictionless, and this is a static problem, so there's no turning … that force shouldn't be there. :frown:)
But, although you've drawn lots of forces, you haven't drawn the force between the roller and the plank.
Which direction do you think you should draw it (and remember, it has to go through both the roller and the plank …)? :smile:
Natbird - sorry to be dancing around the answer, here, but it will really do you good to find the answer yourself, so I hope you're not too frustrated.
Look at the point of contact between the roller and the plank. The roller is frictionless, so can exert no "side to side" forces, right? Kind of like a frictionless surface that can exert only a normal force.
What would that look like from a cylindrical roller??
I'm confused how is a cylinder roller different in this case then? it it's Normal force mgcos59*?
Natbird said:
do I take into consideration a horizonal force from the roller and a vertical force
using sums of those vectors as the final force by the roller on the plank?
http://smg.photobucket.com/albums/v231/er1smesp00n/?action=view&current=angles.jpg
am I even close?
Yes, your red arrow is the force from the roller! :smile:
But your reasoning is weird.
Forget components … the force isn't there because the components somehow create it … the force is there, well, because it's there!
You may need to find the components later - they may be vertical and horizontal, or normal, or …
Wait and see!
Let's see … you now have the direction of that force … so the next step is to find its magnitude.
The system is in equilibrium (not moving), so take moments about some point that will help you find it. Which point do you think that should be? :smile:
On the most recent FBD you posted, the big red arrow (with the two yellow arrows) is what we've all been hinting at. Before, you had two unknowns (the 2 yellows) and now you have one unknown (red arrow's magnitude) and one known (angle). You should have all you need now. Three equations with three unknowns (normal, friction, and roller forces), after you take tinytim's advice and fix your torque equation.
taking the axis at the ground below the roller
sum of x direction=Fsin59*-friction=0
sum of y direction=Fcos59*+N-mg=0
sum of torque=Fsin59*(h)-N(h)/sin59*-mgcos59*(1.7)=0
solve for F by setting the N= to mg-Fcos59*
are those formulas correct??
Really close! Everything except the torque eq. looks good to me.
First, what is the point around which you're defining the torque? It's important to pick this point and then to define your r vector relative to that point. It can be anywhere, since there's no rotation and therefore no net torque around any point, so pick a sensible point. Keep in mind that if the r vector to anyone of the forces happens to be zero, then you can ignore that force since it exerts no torque around that point.
Anyway, think through r X F for each force that's not through your selected point, and then make sure you've got the sines and cosines right ... you're almost there!
If you choose your axis in a different place you may find that your torque equation simplifies. You eliminated the roller from the torque equation because, since this force acts 0 m from your chosen axis, it exerts no torque. Try to choose an axis that eliminates two terms rather than one.
I think the sum of the torques is actually equal to the equation
Fsin59*(h)-N(h)/sin59*[+]mgcos59*(1.7)=0
since if I take the axis from the point I did the plank would rotate counterclockwise
if I take the orgin as the spot where the plank touches the ground would that be easier
sum of torques=Fsin59*+Fcos59*(h)/sin59*-mgcos59*(1.7)=0
This still doesn't look right to me ... try taking it one step at at time:
Where is the axis of rotation? Just state it for the record.
What forces exert torques about that axis?
For each of the forces you just named, what is the r vector, and what is the angle between this r and the force vector?
For each force, which direction is the torque that it exerts?
Once you've answered all those, you can sum them up with opposite signs for oppositely directed torques (this should happen automatically if you do the cross products carefully, using the right hand rule correctly) and set the sum equal to zero.
I think I'm going to change my axis of rotation to make it a little simplier. the orgin for the axis will be the spot where the plank touches the ground. This should leave the only unknown F since the distance from N is 0 setting N to zero since Torque=FxR
next the force due to the weight should cause a clockwise rotation
-(F*r*cos(pheta))==(-mg(1.7)(cos59*)
next the force due to F of the roller
this is now what I'm not entirely sure of. It is positive since the force will cause the plank to rotate counter clockwise. What I was doing was using both horizontal and vertical components- but could I combine them into one?
Froller*r*cos(pheta)==Froller(1.6/sin59*)(cos59*)
then I would know 0=Froller(1.6/sin59*)(cos59*)-mg(1.7)(cos59*)
is that correct?
sum of torque=Fsin59*(h) - N(h)/sin59* - mgcos59*(1.7)=0
hmm … bits are correct. :smile:
Let's just do the torque, for the moment. (:rofl:)
If N is the reaction at the roller (btw, I would have used R!), then N(h)/sin59*-mgcos59*(1.7) is correct.
But what is Fsin59*(h) supposed to be? If F is the reaction at the ground, then it has zero moment about that point.
And how could you solve for F with an equation has both F and N unknown?
Finally, your diagram is very pretty (btw, what software did you use?), but you haven't put in either the weight force or the ground force, and you haven't given any of the forces (or the angle) names.
It is very important to do a proper diagram at the start. Not to impress the examiner, but because it actually helps to stop you leaving things out or putting things in that you shouldn't.​
Try the torque equation again! :smile:
1. What is torque?
Torque is a measure of the rotational force or moment applied to an object. It is calculated by multiplying the applied force by the perpendicular distance from the point of rotation to the line of action of the force.
2. How do you calculate torque?
To calculate torque, you need to know the magnitude of the force applied, the distance from the point of rotation to the line of action of the force, and the angle between the force and the lever arm. The formula for torque is T = F x d x sin(theta), where T is torque, F is the force, d is the distance, and theta is the angle between the force and the lever arm.
3. What is the equation for solving a torque question involving a plank?
The equation for solving a torque question involving a plank is T = M x g x L x sin(theta), where T is torque, M is the mass of the plank, g is the acceleration due to gravity, L is the length of the plank, and theta is the angle between the plank and the horizontal surface.
4. How does the mass and length of the plank affect the torque?
The mass and length of the plank both affect the torque. As the mass increases, the torque also increases, assuming the other variables remain constant. Similarly, as the length of the plank increases, the torque also increases. This is because both the mass and length contribute to the lever arm, which is a factor in the torque equation.
5. Can torque be negative?
Yes, torque can be negative. This happens when the applied force and the lever arm are in opposite directions. In this case, the torque is calculated as a negative value, indicating that the rotational force is in the opposite direction of the applied force.
