• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Torque Question
  • Thread starter wickid
Hello,
I have been stuck on what is probably a fairly easy physics question involving Torque.
A high speed drill develops 0.500 HP at 1600 RPM. Wjat torque is applied to the drill bit?
I have the formula as T=P/Omega
P=.5 HP which I am unsure if I need to convert to another measure of unit
Omega = 1600 RPM which I am pretty sure needs to be converted into Degree
If someone could please help me set the problem up with the proper units, I would really appreciate it.
87
It depends what units you want the Torque in.
You would have to be aware that 1HP is equal to 550 ft.lb/s, you also need to convert RPM to rad/s (multiply by 2pi/60), which is indicated by the word omega (angular velocity).
This produces the formula [tex]T=\frac{33000HP}{2{\pi}N}[/tex], and will be in lb. ft.
Thank you for your response,
I am a bit confused as to how you got 33000HP.
Also to get Rad/S, I thought we would take 1600 RPM/60 s = 53.33 RPS * [tex]{2{\pi}[/tex] = 167.467 rad/s
Does the N refference Newtons in the divisor, or is it a number or another unit?
Also when using HP, we are converting to ft lbs, if dividing by omega in Rad/S aren't we using both british and metric units? Shouldn't we use degrees/s instead of Rad/s as they are both british units?
Please forgive me is I am missing something really basic, and I appreciate your assistance.
FredGarvin
If you want to keep the HP and rpm units a direct calculation is:
[tex]HP = \frac{T \omega}{5252}[/tex]
That will give you the resultant torque in ft-Lbf.
87
The formula you have (T=P/omega) is is based on a metric system (i.e. standard SI units). HP is more of a imperial measurement.
The conversion of HP to ft.lb/s is by a factor of 550, the conversion of RPM to rad/s is by a factor of 2pi/60. And I should of mentioned that N represents the RPM. If these factors are included in the formula you gave above you get.
[tex]T=\frac{P}{\omega}[/tex]
[tex]T=\frac{HP*550}{N*2{\pi}/60}=\frac{60*550HP}{2{\pi}N}=\frac{33000HP}{2{\pi}N}[/tex]
On the note about degrees. Radians are always used in angular velocities and torques etc whatever the bias of other force units.
It may be best/easier (or more logical) to forget about the formula above and simply convert the HP to its lb.ft/s, the RPM to rad/s and plug them into your T=P/omega equation.
krab
Yes, [itex]\tau=P/\omega[/itex] and [itex]\omega=2\pi f[/itex], where f is the revolution frequency; it is 1600 min^-1 or 26.7 s^-1. P=0.5 hp=275 ft-lbs/s. Now: Don't worry about systems of units! Just see whether or not the units cancel:
[tex]\tau=\frac{275\,\mbox{ft.lbs/sec}}{2\pi\times 26.7\,\mbox{/sec}}[/tex]
Notice that the inverse seconds in the numerator and denominator do cancel. That's what you want. Do the math and you are left with ft.lbs.
Thank you for your explanation.
Using your conversions and formula, am I correct in saying that the answer is Torque = 1.64 ft-lbs?
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
