Exploring Torque: Calculating and Understanding Its Definition
  • Thread starter physics user1
  • Tags
    Torque
In summary, the definition of torque is the product of the distance (r) from the axis of rotation and the applied force (F). Torque can be defined in a non-rotational situation, such as when a force is applied at a distance from the axis of rotation, and the amount of torque depends on the length of the lever-arm.
physics user1
The definition of torque is τ= r x F
Let's consider a disk that is rotating around his axis of symmetry, we are usually used to calculate the torque applied by a tangential force at the disk using as r the radius of the disk, but can I define a torque of the force using as r the generic distance between a point external of the disk? In this case will be the torque by this point different by the one referred to the axis of rotation? In my opinion yes because it's the most logical thing
Can we define a torque in a non rotation situation? Think at a particle that is pulled by a force in a uniform accelerated motion, according to the definition of torque we can choose a point in space and get the distance between that point and the force and get a torque, is that right?
Yes, the definition of torque says noting about rotation.
Likes billy_joule
one can define a torque from taking radius vector from the axis and the force vector applied at a point on the body- as its a vector product the torque will generate a rotation due to application of the force. so you can not say that its a non rotational system.
... but can I define a torque of the force using as r the generic distance between a point external of the disk? In this case will be the torque by this point different by the one referred to the axis of rotation?
The answer to the first question is "yes" -- this is what happens every time a wrench is used to turn a bolt or a nut; the force is applied at some distance external to the bolt head or nut.
The answer to the second question is, "it depends" -- the same force (F) applied to a longer lever-arm (r) will yield a proportionally greater torque. Said another way, a longer lever-arm allows the same torque to be developed with proportionately less force.
1. What is torque and why is it important in science?
Torque is a measure of the force that causes an object to rotate around an axis. It is important in science because it helps us understand rotational motion and how forces act on objects in motion.
2. How is torque calculated?
Torque is calculated by multiplying the force applied to an object by the distance from the axis of rotation to the point where the force is applied. Mathematically, it can be expressed as T = F * d, where T is torque, F is force, and d is the distance.
3. What are some real-world examples of torque?
Some common examples of torque in everyday life include using a wrench to loosen a bolt, opening a door, and riding a bike. In all of these scenarios, a force is applied at a distance from the axis of rotation, causing a rotational motion.
4. How does torque relate to angular acceleration and rotational inertia?
Torque is directly proportional to angular acceleration and inversely proportional to rotational inertia. This means that a greater torque will cause a greater angular acceleration, and a larger rotational inertia will require a stronger torque to produce the same angular acceleration.
5. Can torque be negative?
Yes, torque can be negative. A negative torque indicates that the force is causing the object to rotate in the opposite direction, or clockwise instead of counterclockwise. This is important to consider when calculating net torque on an object, as negative torques can cancel out positive torques.
  • Mechanics
  • Mechanics
