Torque is a measure of the force that causes an object to rotate about an axis. It is usually represented by the symbol "τ" and is measured in units of Newton-meters (N·m).
Torque is directly proportional to the angular acceleration of an object. This means that the greater the torque applied to an object, the faster it will rotate.
The torque required to rotate a ball depends on several factors, including the mass of the ball, the radius of the ball, and the angular acceleration desired. Additionally, the surface of the ball and the surrounding environment can also affect the torque required.
The torque required to rotate a ball can be calculated using the equation τ=Iα, where τ is the torque, I is the moment of inertia of the ball, and α is the angular acceleration. The moment of inertia can be calculated using the mass and radius of the ball.
Torque can be applied to rotate a ball using a variety of methods, such as applying a force to the ball at a distance from its center of mass, using a lever or pulley system, or using a motor or engine. The direction and magnitude of the torque will determine the direction and speed of the ball's rotation.
