Torque using i, j & k-hat
A wheel of diameter 34.0 cm is constrained to rotate in the xy plane, about the z axis, which passes through its center. A force vector F = (-30.0 i-hat + 39.6 j-hat) N acts at a point on the edge of the wheel that lies exactly on the x axis at a particular instant. What is the torque about the rotation axis at this instant?
2. Relevant equations
Torque=R*F
3. The attempt at a solution
Tx= 0
Ty= 0
Tz= 6.732
*EDIT* SOLVED *EDIT*
Hi, Stryder_SW!
What component of the force creates the torque? I can tell you that it's not the vector given.
tiny-tim
25,799
242
1,962
411
You have written Torque = R*F but it should be T = R x F. This is important.
Um...what part of that is important?
tiny-tim
25,799
242
Dr.D :smile: and I may be wrong, but we think you're trying to multiply F by the number r,
instead of cross-producting it with the vector r :wink:
1,962
411
The x is important.
No, you're right. by cross-producting it do you mean like dot product? and even if you did this how is the torque in the Tz/k-hat direction not zero when there is no force applied in that direction
1,962
411
Most specifically the cross product is not a dot product. A cross product is a vector, perpendicular to the two original vectors, in the direction given by rotating the first vector to the second vector and applying the right hand rule. The magnitude of the cross product is mag(r x F) = r*F*sin(r,F).
tiny-tim
25,799
242
still can't tell whether you've got it :redface:
dot product is almost the opposite
have a look at the PF library entry on cross product :wink:
EDIT: oooh, the doctor beat me this time! :biggrin:
Well I've never seen cross-product before, and the PF library explanation...kinda confuses me. So I looked it up in my physics book, apparently its not discussed until the chapter AFTER the one that this homework is in. I'm gonna take a look at the book now and hopefully I'll get somewhere.
Awesome, the explanation in my book was surprisingly good. Got the problem using the cross-product. And I think I get why that works, anyways thank you very much for your help.
The Physics Forums Way
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
