Torques on a door with hinges
  • Thread starter darkduck
Consider a do or, hanging on two hinges (s ee figure). The do or is L tall and
d wide, and the hinges are placed at heights L/4 (point A) and 3 L/4 (point
B) from the floor. The door is uniform, and so its centre of mass is in the
middle of the door (point C)
b) What is the torque from each of the 3 forces around point A?
[/B]
I'm not qute sure what i'm going to do. Are the forces from the two hinges pointing upwards or 45 degrees north east?
When i'm going to find the torques around point A, should i just use T=fx ? The torque to point B will then be straight forward, but for find the torque to point C i have to decomposed the direction 45 degrees north east?
Answers and Replies
haruspex
Insights Author
2020 Award
36,163
6,782
They will have an upwards component, but until you've done the algebra you won't know what the horizontal components are or what direction the net force is in. What equations can you write?
That depends on what T, f and x are ;). Seriously, nobody can answer that until you define them.
Is the forces right on that drawing?
When i'm going to calculate the torque around A, the torque of A will be 0 (because the arm is 0). Is it right that when I shall find the two others torques around i have to use the arm times the force?
When i'm going to find the torque around A from B:
The lenght to B from A = 3L/4 - L/4 = L/2
T=L/2*Cosx*B
is this correct?
nasu
433
What is B here? The force at B? What is x?
B is the force at B. X is the angle, because it's unknown...
nasu
433
Cos x may be or not correct, depending on which angle you call x in your drawing. The general formula for torque is a cross product, so the magnitude is written in terms of the sin of the angle between the two vectors. But if you use the complement of the angle, it may be cos.
You also can write the torque by using the components of B. It will be simpler. Anyway you will need to write the balance of forces and teh balance of torques by using components.
haruspex
Insights Author
2020 Award
36,163
6,782
Further to nasu's reply, you should not assume the angle of the net force is the same at both hinges. Just put in four unknowns for the horizontal and vertical components of force at each hinge.
but shouldnt the forces from hing A and B have opposite directions in the x-axis to get static equilibrium?
nasu
433
Yes, they should.
haruspex
Insights Author
2020 Award
36,163
6,782
Yes, the horizontal components must be equal and opposite, but you don't yet know whether the vertical components are equal. It is likely from the symmetry of the hinge positions that they will be, but it needs to emerge from the equations.
is it wrong to write that the Torque from hing A to point C = -d/2*Mg ? where d/2 would be the lever-arm and (-) because of the clockwise rotation ? ?
PhanthomJay
507
Watch terminology. The torque about A from the vertical force at C is not the same as the torque about C from the vertical and horizontal forces at A. In fact, it is not possible to determine the vertical force at A from the equilibrium equations. Let's not lose sight of what the original problem is asking: what is the torque about A from each of the three forces C_y, B_x, and B_y? (The sum of which add to 0).
the Torque around A from the force B_y should then be equal to 0,because of that the vectorproduck = 0, and therefor the Torque around A from the forces could be that
r1*FBx*sinθ = r2*FGysinΦ
where r1 should be ½*L and r2 should be √((¼*l)2+(½*d)2) ?
PhanthomJay
507
yes
well OK using cross product rule
yes, and where θ is 90 degrees and thus sin θ is 1
well, yes, but where sin Φ = 1/2 d/r2, so r2 cancels out , no need to calculate it.
When breaking up forces into x and y components, instead of using the cross product rule, note that the moment of a force or force component about a point is the product of that force or force component times the perpendicular distance from its line of action to the point. Makes things a lot simpler. The moment of the gravity force at C about A has already been correctly calculated somewhere in the above posts.
Thanks for a good answer! :)
iamnotsmart
yes well OK using cross product ruleyes, and where θ is 90 degrees and thus sin θ is 1 well, yes, but where sin Φ = 1/2 d/r2, so r2 cancels out , no need to calculate it.
This may be a couple of years back, but I somehow have the same problem in my hand right now. I sat it up just like all of you, the torque around A needs to be equal 0, where the ones that give torque is the x-component of the force from hinge A and the perpendicular distance of r-vector from A to C (aka d/2) times Fg. However in the next task, we are asked to do the same around B, and I literally get the same thing again. The next task is setting up two more equations when you the door doesn't fly sideways or upwards and so on, which is just that x-component of hinge force A and B equals 0. Both of the vertical components from A and B needs to cancel out gravity force. The last task, we were asked to solve for the complete hinge force vectors when we know that the vertical components of A and B are the same, aka 2Hinge(Y)=Fg. I have no idea how to find this as the equation of F_a_x-F_b_x=0 is useless when we already know when calculating torques around A and B that x-component from A and B is the same. What do I even do next? Sorry for this long post, but I have been sitting here, trying everything and frustrated :/
haruspex
Insights Author
2020 Award
36,163
6,782
I am not quite clear what you are told and and what you are struggling with.
You are told to assume the two vertical reaction components are equal, yes? So you can calculate those vertical components.
If you mean the x components, you already have those from the moments balance, no?
If they were exactly the same the door would accelerate sideways.
iamnotsmart
b) What is the torque from each of the 3 forces around point A? c) What is the torque from each of the 3 forces around point B?
d) For the door not to rotate, the sum of all the torques must be zero, around any point. Write down the corresponding equations.
e) For the door to neither fly sideways, upwards or downwards, what other two equations can you write down for the forces?
f) We will assume that the upwards components of the two hinge forces, FyA and FyB, are the same. Solve for the complete hinge force vectors.
iamnotsmart
I mean the absolute value of x-component of A and B is the same, but they act in opposite direction so they cancel out each other? And that's why the door doesn't move sideways? Anyways that's what I found out in b), c) and d), that they are the same, but in opposite direction. However in e), we were asked to write the equation where x of A and X of b is equal to 0 when we already knew it in the previous questions? And how do I use all of these equations to solve for f)?
haruspex
Insights Author
2020 Award
36,163
6,782
Ok, but this leaves me baffled as to where you are stuck. What is "this" in "I have no idea how to find this"?
iamnotsmart
Question f), I don't really understand what we have to find or how to do it... Are we going to find an expression of the hinge force or what? I don't really know lol
haruspex
Insights Author
2020 Award
36,163
6,782
Right.
Yes. In 2D statics there are only three independent equations available. Mostly people write two linear force equations, usually for two directions at right angles, one one moment equation. But one linear and two moments also works. You have been asked to write four, so one of them will be redundant.
This is where I am puzzled that you are stuck. You know the horizontal components and you have two equations for the vertical components.
haruspex
Insights Author
2020 Award
36,163
6,782
All they are asking for is the horizontal and vertical components of each hinge force. If you have been taught a vector notation, like ##x\hat i+y\hat j##, then use that.
iamnotsmart
Right.
I don't know what the task is asking for. As you can see, English is not my primary language, pretty hard to transfer everything I have learned earlier in another language to English right now.
And how do you manage to get two equations for vertical? b) and c) gives an equation in d) where the sum of torque around point A and B equal to 0. Only the x-components matter here as far as I am concerned, cause they are the one perpendicular to radius vector. e) gives another equation for the x-components and one for the vertical components canceling out gravity force. And I don't know anything about hat or something like that lol.
Related Threads on Torques on a door with hinges
  • Last Post
  • Last Post
  • Last Post
  • Last Post
18K
12K
  • Last Post
