Torricelli's Law Problem
Okazaki
56
(This is a continuation of the problem where I proved Torricelli's Law: v = (2gh))
The water level in a tank lies a distance H above the floor. There is a hole in the tank that a distance h below the water level
a.) Find the distance x from the wall of the tank at which the leaked stream of water hits the floor
b.) Could another hole be punched at another depth h' so that this second stream would have the same range? If so, at what depth?
Δx = (vf2 - vi2)/g
v = (2gh)
At first, I was not really sure what to do here at all (and I probably ended up solving it completely wrong.)
So, basically, I wasn't exactly sure how to find the distance, since I only knew the initial velocity in the x direction (or, at least, I assumed v = (2gh)) was the velocity of the water in the x direction based off the picture in the problem.)
So, what I tried was:
(Since the equation I had to derive from Torricelli's law in the problem I had to do before this ended up being Δv = (2gh), I assumed:)
Δx = (2gh)/g
= 2h
For b, I'm completely confused on even where to begin solving for the equation.
Answers and Replies
13,009
Where does that Δx formula come from?
Your water, once it leaves the tank, moves horizontally and is in free fall. What do you know about objects in free fall?
Okazaki
56
Wait a minute...the water has a vy when it leaves the tank of 0 m/s, doesn't it? If so, then I think I can solve it.
13,009
Right, assuming "y" is your vertical coordinate.
Okazaki
56
Well, I over-thought that problem.
Then:
vi-y = 0 m/s
So:
==> vf-y = vi-y + 2gh
= 0 + 2gh
= 2gh
So:
vf-y = vi-y + gt
t = vf-y/g
==> t = (2gh)/g
So:
This is where I use: v = (2gh)
Δx = vi-yt + 0.5at2
= (2g*(H-h)) * (2gh)/g
= 2 √(h(H-h))
Still not sure about b, though. Would I just work backwards?
haruspex
Insights Author
7,954
Δx = vi-yt + 0.5at2
= 2 √(h(H-h))
If a hole at height h' produces the same Δx, what equation can you write?
13,009
A velocity cannot be equal to 2gh, the units do not match. And I don't understand the other steps, but the result looks right.
Okazaki
56
v = (2gh) was what I had to prove in the previous problem.
Okazaki
56
Wait, I see the issue. In my notes, I think I had a square root sign. It just never made it onto paper.
Okazaki
56
Well, if it's at h', then the Vi-x will be √(2g(H-h')) and you can work backwards from there.
haruspex
Insights Author
7,954
Better, consider h' in respect of this equation in your post #5: Δx = 2 √(h(H-h)).
13,009
Drawing a sketch of Δx as function of h could be useful.
Suggested for: Torricelli's Law Problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
