Homework Help: Torsion spring constant
  1. Sep 5, 2011 #1
    I need to calculate the spring constant of a torsion spring.
    Turns : 20
    Mean Diameter : 6mm
    Wire Diameter : 2mm
    Material : ASTM A228
    Arm Length : will be negligible, as they will be fixed
    Orientation : Arms inline
    2. Relevant equations
    [itex]k=\frac{Ed^4}{10.8DN}[/itex]
    3. The attempt at a solution
    Subbing values in i get a spring constant of 1.944 Nm/revolution
    Does this look correct to you?
    Am i using the right equation?
    If the one arm is fixed and the other is rotated (with arm length 25mm) 1/4 revolution does this result in 1.944/4*0.025 = 0.01215 N or 1.944/4/0.025 = 19.44 N at the end of the arm?
  3. Oct 17, 2011 #2
    I'm not exactly sure what modulus you used but ASTM A228 is music wire so E≈207GPa. With that value the spring constant I found was:
    [tex] \kappa = \frac{Ed^4}{10.8DN} = \frac{(207GPa)(2mm)^4}{10.8(6mm)(20)}=2.556Nm/rev [/tex]
    As for your question, to calculate the force the spring will apply you need to multiply the spring constant by the deflection and then divide the resulting torque by the moment arm (arm length). Therefore if the spring is deflected a quarter turn and the free arm is 25mm long:
    [tex] F=\frac{\kappa \delta}{L}=(2.556Nm/rev)*(0.25rev)/(0.025m)=25.56N [/tex]
    Hope that helps.
  4. Oct 18, 2011 #3
    Yes that help alot... Thank you... I was being stupid at the end and not thinking about the units... Newton meters divided by meters provides newtons... Duh... After redoing the number i get your value... Thanks
    (sorry bout the formating, done on my phone)
Loading...
