Total Energy Dilemma: Cruiser vs Battleship
In summary, the physical problem presented to the student is that the energy in two systems which are moving towards each other is not the same. However, this is still a physical problem because the conservation of momentum laws still apply.
Mephisto
93
I was presented with a very simple physics problem today which unfortunately stumped me for some reason:
you have two spaceships: a cruiser weighing a ton, and a battleship weighing 100 tons. Now let's say the cruiser is moving towards the battleship at constant speed. From battleships point of view, the cruiser is coming towards it, so energy in the system is just 1/2 m_cruiser v^2. But from cruisers point of view, the energy in the system is 1/2 m_battleship v^2, which is MUCH greater since m_battleship >> m_cruiser.
So the energy in the two systems is different, and yet isn't that exactly the same physical problem? This is such a noob question i almost feel bad asking it.
What's the problem? Energy conservation laws are applicable in any inertial system, but you can not "jump" from one system to another so easily. Energy is not a constant value which does not depend on choice of system.
Hi Mephisto! :smile:
If m(a² - b²) + M(c² - d²) = 0,
then m((a-v)² - (b-v)²) + M((c-v)² - (d-v)²) = 2m(bv - av) + 2M(dv - cv);
which is zero, from conservation of momentum. :smile:
KE is frame dependent
The speed and thus kinetic energy of an object depends on the frame doing the measurement. But that doesn't change any physics. (Conservation laws will work the same from any inertial frame's viewpoint.)
omg, that makes perfect sense. even when you calculate the potential energy of an object due to gravity you take an arbitrary reference point. I should have remembered that. All that matters is that the conservation laws work. Stupid me :) thanks
1. How does the total energy consumption differ between cruisers and battleships?
The total energy consumption of a cruiser is significantly lower than that of a battleship. This is due to the fact that cruisers are smaller and lighter, requiring less energy to operate. Additionally, cruisers are designed for speed and maneuverability, while battleships are designed for power and endurance, which also contributes to the difference in energy consumption.
2. Which type of ship is more environmentally friendly?
Cruisers are generally considered more environmentally friendly than battleships. This is because they consume less energy and emit fewer pollutants into the environment. However, both types of ships still contribute to environmental damage and efforts are being made to improve the sustainability of naval vessels.
3. How do the energy sources for cruisers and battleships differ?
Cruisers and battleships both use a combination of traditional fossil fuels, such as diesel and gasoline, and alternative energy sources, such as nuclear power and renewable energy. However, battleships typically rely more heavily on traditional fuels, while cruisers may have a larger percentage of alternative energy sources in their energy mix.
4. What are the main factors that contribute to the total energy dilemma between cruisers and battleships?
The main factors that contribute to the total energy dilemma are size, design, and purpose. As mentioned before, cruisers are smaller and lighter, while battleships are larger and heavier. This affects their energy consumption and sources. Additionally, the design of each type of ship, with cruisers focusing on speed and battleships focusing on power, also plays a role in their energy needs.
5. How can the total energy dilemma between cruisers and battleships be addressed?
The total energy dilemma can be addressed through a combination of technological advancements and strategic planning. This includes developing more efficient propulsion systems, utilizing alternative energy sources, and optimizing the design and operations of naval vessels. Additionally, implementing sustainable practices and reducing energy waste can also help address this issue.
  • Other Physics Topics
  • Classical Physics
